Javelin
All windows removed, area cleaned, old sealant removed, holes and any damaged areas re-glassed and gelled.
Apertures re-cut to make the windows 30mm higher and slightly longer as she's a bit gloomy down below.
The actual holes were pretty badly cut out in fact, probably due to original self build and in places just a mm or so of grp beyond the fixings.
Plywood templates made of new apertures with amount of curvature needed in frames and sent to our previous window maker.
Headlining removed and new fitted with better insulation and led lights.
New windows fitted with new internal trims.
Big fail on the aft two windows however (hence previous window maker).
Its a center cockpit countess 33 and the aft two windows have quite a lot of radius given their length and simply, they didn't fit.
Our fault as when I checked the frame curvature that our (shall be nameless) employee sent it was 20mm too much.
Not a happy bunny.
I decided to make a grp template of the window area so they had a stiff, accurate reproduction to work with but their quote was frankly astronomical and they still said that it wouldn't be exact.
Sorry not good enough.
Hate it when a rep say's he can match all radii and then prove they can't.
Anyway after quite a lot of to-ing and fro-ing I've decided to give another manufacturer have a go at less than half the cost and am awaiting their solution, the down side is these new ones will use inter-screws, which I hate with a passion but if they fit for less than half the cost I can't argue.
Also fitted new cutlass bearing and re-aligned the engine.
New VHF and AIS transponder.
New standing rigging and 2:1 main halyard and Harken top sheave as owner's shoulders are not as strong as they were, plus various running rigging changes.
Stack pack and simpler reefing system.
Better quality mainsheet traveler as the old one was horrible.
New sprayhood and associated cockpit cover.
Not a happy bunny.
