thinwater
If you are using chock blocks (screw terminals of any sort) in damp areas you can always use boot lace ferrules to seal the insulation. Just sayin'.
You can if they fit. I use these with shrink wrap where possible but some LED light fittings are too small to make these connections. There isn't enough space in the fittings.If you are using chock blocks (screw terminals of any sort) in damp areas you can always use boot lace ferrules to seal the insulation. Just sayin'.
That is just not right. If you seek advice in this forum then choose to ignore it then that's fine but don't argue you are right. If you didn't get the advice you wanted you shouldn't have asked. You cannot heat shrink every end terminal on every device. Light fittings often have chocolate block type fittings. There isn't room to add crimp on terminals and heat shrink. These circuits will be susceptible to corrosion if you choose to use none tinned wire. It happened on my previous boat. All wire needed to be stripped out.
If you build your boat and sit in a marina or don't sail in poor weather you may well find you get away with none tinned wire for quite some time. If you have a leak from a hatch, deck fitting, etc and your light fitting gets wet from salt water you will possibly need to strip out your wiring and replace it. This is the kind of thing that does happen. It's why those with many years of cruising experience give you advise to this effect
True, but have you ever tried to get black wire clean enough for the solder to stick? I have. I don't bother now, I just replace it if it needs soldering.If you solder the ends of untinned wire it's tinned
If you solder the ends of untinned wire it's tinned, the blackening along the length makes no odds unless it corrodes through.
Soldering wire ends used in mechanically made electrical connections has 2 problems. These are:
1) It creates a hard spot and hinge point that is often unsupported by the wire's insulation. The soldered wire is hard and inflexible and transitions to flexible unsoldered wire usually without support from the insulation. Movement and vibrations will cause bending at this interface eventually leading to fatigue failure. Although crimp connections also have this inflexible to flexible transition, when a crimp is done correctly the insulation is also crimped and supported so that there is no unsupported hinge point.
2) Solder has a high creep rate when mechanically stressed. This can cause joint failure much quicker than 1) above. If you solder a wire end and then make a mechanically made connection with it, either crimped or some other kind of squeezed or screw down, the solder is mechanically stressed and slowly starts to deform plastically via creep. This will loosen the connection leading to possible failure, sometimes in only months. In addition it allows oxygen in initiating corrosion. The tinning on tinned wire is such a thin layer that any creep effect is negligible and crimped/squeezed connections are as good as untinned wire.
In situations where safety is a factor soldered wire ends in connections are explicitly banned. On a boat, you'll most likely get away with it, but have less reliable shorted service life wiring. Crimp and ferrule connections are cheap, quick and reliable and should be used preferentially to anything else.
Angus what do you do if you want to connect a cable to a BUS BAR that has grub screws?
And I thought anchor threads were controversial!
I would add, use conduit in areas where replacement would be difficult and install draw wires as you never know when you might want to add new wiring.No controversy really. It's all standard industrial practice that boils down to only 3 rules...
1) Use cable that is suitable for your application and budget.
2) Use crimp connections wherever possible.
3) Support and protect your wiring.
[/QUOT
Those sound like cabin lights, so they are in a dry location.
I'm not looking for an argument!
0:00 / 25:14 How To Terminate Wires 101 Tutorial. Crimp Solder Shrink [WIRING 101]
I was just thinking this.And I thought anchor threads were controversial!
Actually that’s not correct. The ‘blackening’ along a wire does impact its current carrying ability. Maybe not enough to affect a low frequency signal wire from an engine but certainly on something higher current.If you solder the ends of untinned wire it's tinned, the blackening along the length makes no odds unless it corrodes through.
a few people harvest stuff off the net then spout it in here as their own experience which is dangerous. People with real experience are ignored. The trick is to work out who to listen to.
You know what I meanWell maybe good advice , BUT , I have never heard anything on these pages , ONLY READ stuff - what am I doing wrong ? {)#
