Baggywrinkle
... I just got back from a charter of a Sun Odyssey 409 with a stack-pack as the 409/419 is one of the boats on my shopping list and I really want to love stack-packs for the sailing advantages. After years of sailing with a roller reefing main here are my observations - any comments or tips and tricks to make this work better would be gratefully received.
Disclaimer: I am not tall, 1,65m ... this is fundamentally what caused me the most issues, and is probably the same for all AWBs with booms high above the cockpit on top of a bimini. We are a cruising couple (my partner is even smaller than me) and apart from the main sail, sailing the boat was absolutely no problem for the pair of us.
1. Getting the main up was not a problem apart from the baton ends getting caught in the lazy-jacks - the view from the cockpit with sprayhood and bimini was severely compromised so I ended up raising the main standing on the companionway steps while peering up through the sprayhood. loosening and tensioning the lazy-jacks didn't make much difference and it only really worked head-to-wind, easing the batons past the lazy-jacks - How can this be prevented? Sail modifications?
2. Dropping the main was easy and it fell nicely into the sail bag, but the flapping main halyard in the large swell kept pulling about a meter to a meter and a half of sail back up the mast, trying to let out more halyard didn't work as there was too much friction in the blocks and mast so I had to grab the halyard at the mast. The mast was equipped with 2 mast steps to reach the halyard - it was a stretch for me and hanging onto the mast a meter above the deck while trying to grab the main halyard and tame it was precarious in the swell. I ended up using a boat hook to grab it and pull it down to a cleat to make it fast - there was no way I could detach it from the main in a swell. How do others tame the main halyard? Can it be done from the cockpit?
3. Zipping up the sail bag was a non-starter - I simply could not reach the end of the boom without taking the bimini down and standing on the cockpit seats or table - even then it would be a stretch. The sprayhood and bimini were so large there was no way I could reach around them - I can't be the only person with this problem, how do others solve it?
4. Never needed to reef, but I have done it in another similar boat and single line reefing worked fine - the only gripe being that only 4 sail sizes are available compared to an infinitely variable roller main. This is not a dealbreaker though.
5. The fully battened main was far nicer to set and sail compared to the roller reefing I am used to, going head to wind to raise and lower the sail was the only gripe - is it possible to use a stack-pack to reef or raise/lower the main without altering course?
6. One observation that came as a surprise was getting the boom to stop swinging from side to side. The boat had a traveller on the cabin-top forward of the sprayhood and the boom + sail bag + sail weighed a ton, the tension required in the main sheet and the topping lift to keep it in the centre was scary, it still moved and clanked though. The bare boom of a roller-reefing system is far lighter and stays centered. Maybe two attachment points and no traveller, creating a triangle, will hold the boom steadier?
7. UV damage to the sail is also a worry, if I can't close the bag except with acrobatics and climbing all over the boom, then the sail will remain exposed to UV far longer than a roller-reefing main. Is this an issue in the real-world or just an unnecessary worry?
Finally, how does a vertically battened main on a roller reefing system compare to a fully battened stack-pack main?
