WindyWindyWindy
I have simple slab reefing on a 37' boat.
I'm contemplating spectacles, but are there alternatives? Somewhere in the distant past someone suggested doing this backwards - with a line attached to the gooseneck with a set of toggles/dogbones in it for the reefing points, so to reef you would lower the halyard and pop the toggle through the reef point and haul it back up.
Has anyone actually tried that?
Also, when dropping the main the reefing lines flap around unpleasantly in the cockpit, which enrages the admiral. So I find I have to pull the reefing lines in as I drop the main, which doesn't make for a quick drop and increases wear on the reefing lines substantially as they're now getting pulled tight during each drop. So, I was contemplating adding blocks to reduce the friction a bit, and save my poor arms. But it occurs to me that there's two ways to set these up as well.
One would be to attach the block to the reefing clew and run the reefing line normally up and down. This puts a dangly block on the sail and will surely add chafe.
The other would be to use a strop around the boom holding the block close to the boom and the reefing line running from the back of the boom through the block and tied off the the clew.
Any opinions on my madness? Has anyone actually tried either of these?
