Erik C
Even if the OP doesn't want/need airco for me it would makes sense to fit an airco capable generator anyway thinking it would help the resale value of the boat.
+1What a fantastic first post! Looking forward to the build thread, many congratulations.
Traveled down to Princess Yachts in Mayfair London last week to meet with James and confirm all the order. Nice day checking through the specification, started sweating when James wheeled the Fendi brochures through for my wife to look at!
So here's what we got coming.*
Princess 43 with Volvo D6
Variable Speed Bow & Stern Thrusters
Steel Grey Hull
Walnut Interior Satin Finish
Electric Double Berth Conversion in Cabin
Flybridge Wet Bar with Electric Griddle
Leather Ice White in Saloon
Jacaranda Carpet Throughout
Guest Heads White Mossic Tiles with Black Worktop
Master Heads White Mossic Tiles with White Top
Transom Hydraulics
7KW Generator
40' 3D TV with upgraded Fusion AV700i
Raymarine E125 Chart Plotter Lower & Upper Helm
Volvo Interface to Raymarine
Eberspacher Heating
System 2 Y Valve Holding Tank
Some other techie bits discussed which I'll go into some more detail later once we get further down the line.
If you can think of anything I've missed let me know?
7Kw is fine for running airco on a 45 foot boat imho. Even if you got a very high end split system you'd want say 4 Tons max, which would be 15 amps for the chiller (soft start) and 4 amps total for the pumps and air handlers. A more basic system would be happy on 15 amps all in. 7kva genset can make say 28 ampsEven if the OP doesn't want/need airco for me it would makes sense to fit an airco capable generator anyway thinking it would help the resale value of the boat.
If you're going to do this you must get the video lead and 12v dc supply installed in the build if Princess will agree. I used a Garmin camera but there are plenty of others you can use. https://buy.garmin.com/en-GB/GB/marine/cameras/gc-10/prod37695.htmlJFM,
If you don't mind explaining, what spec of camera did you use and where did you mount it for the AnCam. Quite fancy connecting that to the chart plotter.
Each to own but I'm happy with Fusion 700. I'm no audiophile but the integration with nav screens is an incredibly useful function. You can adjust volume during dinner from your iPhone - soften it if it is hampering conversation and wind it up for the best bit of the track. I think the head unit is better than the speakers though and I would fit a sub plus maybe swap out the speakers later
Just the standard shafts. No option on the 43 for IPS, which is just fine as I don't really like the IPS units. I think maintenance on those units would be high. Don't have any data of course to support that thought but just a gut feel. The reason I selected the upgrade was really to get a higher spec bow thruster and I occasionally sail on my own so having a hold function might be useful. !
We're getting a few video/audio upgrades done and nearer delivery James from BCU is going to put me in contact with his electrical guy to spec it all out so that may involve head unit upgrade. Is the fusion 700 that bad, need to check the specs.
The Garmin cam is a rebadged one made by another manufacturer whose name I forget but can look up. You can throw the camera away and fit a new one if the elements corrode it after a while, so consider it partly disposable. You need, I suggest, a dome type, not the type that is a cylinder on a stalk. There are no compatibility issues here - so long as the camera is video over coax (not IP) it will feed any modern plotter via the video in socket, and you can mix garmin and raymarine (I don't think Ray make a dome type). You can also use the IP type camera and connect to Raymarine's Ethernet, but I feel that is more complex and doesn't add anything to the proceedings
It's a really worthwhile gizmo in my opinion. I use it every time I anchor
There are 2 schools of thought on mounting - side view (my preference, see first 10 secs of video below, and easier to do if Princess leave you the 2 wires dangling in anchor locker) and top view (see JtB's refit thread, and involves threading cabling in the pulpit tubing). I prefer the side view so the fact it is easier to install is a bonus, but it is each to their own.
Oi! I'll be sending you an AnCamTM royalty invoice if you're not carefulgen Iancam ...
:encouragement:Lucky he only thought of a cunning plan not trick:encouragement:I'm looking forward to hearing your CunPlan![]()
I'll tell you why.Why are we all calling it AnCam?
I can't get my tongue round the word.
I would have thought that AnchorCam was much easier to say.
If you mean in parallel, afaik that's rather tricky. Not just a matter of snaking an additional cable, anyway...I would connect both alternators so that all batteries are charged.
Yup, looking forward to AnCamCunPlanTM. I'm guessing it will take power from the windlass, use an IP cam, and beam wireless pictures
I'll tell you why.
Back in 2013, AnchorCam is actually the name jfm was using for the thing, till during a querelle on its usefulness, someone more used to a language in which AnCam is fairly easy to pronounce came up with the idea of shortening the name - jfm is only guilty to have eventually endorsed it...
http://www.ybw.com/forums/showthrea...3-Fairline-Squadron-78)&p=4267482#post4267482
Nice thread btw, I've only just seen it now.
@ 47GC: "Transom Hydraulics", wazzat?
Good history lesson
Still on history, IIRC you invented the AnCam concept MM didn't you? I mean you were first on here to suggest it (IIRC). Or were you - Hurricane suggests differently above - I'm not sure (?) Would have to look back at Hurricane's build and delivery threads I think
It would be ironic if you invented the concept, and never even liked the thing!
I think 47GC is referring to hi-lo platform, which is an option on princess 43
Nope, I believe it was indeed a Hurricane idea, well at least here in the asylum, anyway. My only contribution was the shortened nickname.Still on history, IIRC you invented the AnCam concept MM didn't you?
