Bojangles
Congrats 47GC, exciting times ahead. Are you already on Loch Lomond?
The P43 production shed is very interesting, I was at the factory for a course when it was the P42 line and every Monday a new lower hull moulding enters the hall and progresses through engine/tankage/shafts and steering installation, then the bulkheads and plumbing/electrics go in, meanwhile the inverted deck moulding is being fitted out as well as the flybridge moulding, these are married about the middle of the week then the interior, cabinetry, carpets,etc, and hook up of upper and lower systems, then every Friday lunchtime a completed new boat leaves the production line, amazing to see, when you consider that layup of just the hull and deck moulding on a MY95 takes 6 weeks.
We visited when ours was being built and they showed us the (then) P42 line.
Your post above doesn't really make it clear that there are a number of boats on the line at various stages of production.
As you say a new hull enters the shed at one end.
But before it enters, it is placed onto a cradle.
Cradles have "train style" wheels and run in a track.
Cradles are then bolted together so as the new hull (on its cradle) is pushed in, the finished boat at the other end of the line "pops out".
IIRC, the P42 was too long to fit into the shed where all the P42s are built so they were set on their cradles at an angle (diagonal) so they they fitted.
IIRC, the P42 was too long to fit into the shed where all the P42s are built so they were set on their cradles at an angle (diagonal) so they they fitted..
Traveled down to Princess Yachts in Mayfair London last week to meet with James and confirm all the order. Nice day checking through the specification, started sweating when James wheeled the Fendi brochures through for my wife to look at!
So here's what we got coming.*
Princess 43 with Volvo D6
Variable Speed Bow & Stern Thrusters
Steel Grey Hull
Walnut Interior Satin Finish
Electric Double Berth Conversion in Cabin
Flybridge Wet Bar with Electric Griddle
Leather Ice White in Saloon
Jacaranda Carpet Throughout
Guest Heads White Mossic Tiles with Black Worktop
Master Heads White Mossic Tiles with White Top
Transom Hydraulics
7KW Generator
40' 3D TV with upgraded Fusion AV700i
Raymarine E125 Chart Plotter Lower & Upper Helm
Volvo Interface to Raymarine
Eberspacher Heating
System 2 Y Valve Holding Tank
Some other techie bits discussed which I'll go into some more detail later once we get further down the line.
If you can think of anything I've missed let me know?
Sounds awesome!
Is it D6 IPS? Bow and stern thruster might be a little ott if so....bow would suffice.
Personall would not bother with the fusion and go for a dealer or post delivery fit of something fit for purpose....it's not exactly leading edge stuff.
Genset should be fine if you are not fitting a/c
Bet you can't wait![]()
Each to own but I'm happy with Fusion 700. I'm no audiophile but the integration with nav screens is an incredibly useful function. You can adjust volume during dinner from your iPhone - soften it if it is hampering conversation and wind it up for the best bit of the track. I think the head unit is better than the speakers though and I would fit a sub plus maybe swap out the speakers later
