doug748
Good idea basically a poacher alarm on a stick. https://www.amazon.co.uk/Bisley-Security-Burglars-Intruders-Galvanized/dp/B0049ACMC6 Easy to recharge and go again. I have some blanks I could try dunking but even if they don't like getting wet its easy to dip the front end in wax. I don't think a solid slug or shot would work without being constrained in a barrel, the cartridge would blow out at the sides. Trouble is if you made anything with any type of barrel you might be liable for making a firearm though if the separate parts were divided about a boat... Even a blank close up would probably be felt as well as heard so would probably be enough. You can buy 12g blanks without a license of any type.
It does look good.
Is that without a licence in the UK? For max effect underwater would be best, do you know if a cartridge would go off under the surface?
