burgundyben
Jesus wept in his weetabix, this is monster shenanigins!
Well done for tackling it.
Lift out went smooth, just a little tricky with the radar arch position,
Engine is in the workshop now,
Boat back in its berth
Flybridge hatch recaulked (tempor.) avoiding water come through,
boarding my plane in a few minutes
Pics will follow
I'm also with old fully mechanical lumps (3208TA) and I like them.I love these old fashion fully mechanical diesel engines.
Yup agree. I've had 3 boats with these engines and never a moment's trouble. Simple things compared to the latest electronically managed lumpsI'm also with old fully mechanical lumps (3208TA) and I like them.
Bart
I think this is maybe the best option long term.
Cat and Cummins have always had a standard repair practice in the event of a spun bearing. Block is machined to take a repair saddle which is manufacturer available standard service repair part. Saddle is riveted in place and block line bored, all a bit of a ***, and blocks comparatively inexpensive. . Your V block is not the greatest in terms of rigidity and I am not sure there is an approved practice for MAN/Mercedes blocks so you are in the hands of a machine shop solution.
Perhaps you should consider a new block. As I mentioned in earlier post MAN and Mercedes shared blocks in this period, Atlantis Diesel (MB Subsidiary) had a large foundry producing these blocks, they used to be two a penny. May be time to look for a replacement.
Thanks to TK we are back on track. Not sure how we ended with excursion into silly pointless CAT 3208 territory. Just waiting for for some clown to start referring to engines as 'lumps', stupid 1980's journalist macho speak.
A bit intemperate, LS1. Who appointed you as the thread drift stasi?Thanks to TK we are back on track. Not sure how we ended with excursion into silly pointless CAT 3208 territory. Just waiting for for some clown to start referring to engines as 'lumps', stupid 1980's journalist macho speak.
if we were that far !! :ambivalence:When the engine is rebuilt and has its cylinder heads on
When the engine is rebuilt and has its cylinder heads on, with it fit down the same gap, or will the passerelle have to be moved? Maybe it is easier to tilt the radar arch back (to allow the crane wire to move 500mm aft, then there is no need to rotate 90degrees) than to remove the passerelle? No doubt you have thought about all this!
but the engine was heavily stripped down.
They have a great deal of confidence on what they are doing!
