jfm
Greetings - loving your pictures!BTW, greetings from Melbourne.![]()
This is under 24m LLL and LH rules, so normal Yachtmaster works ok within the law, and the insurers don't tend to add further rules of their own. I have not organised insurance yet.Thank you for sharing.
What qualification (for Insurance) is required.
Correct - chase boats by definition are not carried on the mother ship.Have you not noticed the set ups in the SoF ?
Tenders tend to be carried on the mothership .
” Chase boats “ chase it .Usually towed , but bigger are crew driven .
Nope!Awesome vessel.... Could this be "THE forever one?"
At 2400hp each it's hard to find an alternative to MTU, and of course its widely regarded as the absolute best engine in its class, so it's a no brainer. All the previous (20 or so) boats in this SL96A series have the V16 MTU in the 2200hp version, and mine will be first/only one with the 2400hp version.OK - so here we go!!
Did you choose MTU or did they persuade you?
From the drawings, it looks like they might have V gearboxes.
What’s the rationale of going bigger Hp wise ?At 2400hp each it's hard to find an alternative to MTU, and of course its widely regarded as the absolute best engine in its class, so it's a no brainer. All the previous (20 or so) boats in this SL96A series have the V16 MTU in the 2200hp version, and mine will be first/only one with the 2400hp version.
These engines are the 2000 series which means (as you know) they are fundamentally the same engine as in your boat, with a few extra cylinders added. Triple turbos.
Yes, on Vee gearboxes.
A few? That's an understatement, if I've ever seen one... Twice the cylinders is more like it!same engine as in your boat, with a few extra cylinders added.
Far from wishing to reply on jfm behalf, but my personal answer would be because you can!What’s the rationale of going bigger Hp wise ?
Yup, will be interesting to hear. My guess is that JV had a problem in some places where shorepower was only available in single phase, whereas these boats (mine included) are fully 3 phase and need 3 phase shorepower and generators. A lot of the motors on board (even the miele washing machines!) are 3 ph and I'll have 3ph shore power in home berth.A few? That's an understatement, if I've ever seen one... Twice the cylinders is more like it!![]()
I'm also curious to hear from JV why he was missing a freq. converter, particularly on a 3-phase boat which is bound to be connected to pretty substantial/stable shorepower lines.
Maybe he used to ship the boat to some 60Hz remote Country during the winter...?
Zero extra fuel burn at cruise. If you can afford it why would you not?What’s the rationale of going bigger Hp wise ?
Assume they occupy identical ER foot print , save a few extra bolt ons like maybe more forced induction hard where?
How many extra knots and how much additional fuel burn that normally comes with that are you getting over stock ?
I mean I can understand with a sporty open say Pershing , Otam , Magnum , Mangusta et al dare I say it Itama going for more , or pressuring the builder upwards in terms of performance .
Also mindful the natural engine manufacturers evolution up the Hp tree for given block.This isn’t it’s a deliberate decision by you to leapfrog up the Hp .Why ? If you don’t mind sharing ?
No need to gamble, if and when you'll like to come to CF.When away in other ports I'm basically gambling that I will be able to find 3ph shorepower in most places.
A few factors in this decision, not in order:What’s the rationale of going bigger Hp wise ?
3Ph available on all dock pedestals where your ship can fit (128A, IIRC).
Oh, and no posidonia BS, either...!![]()
To give the context, the incremental charge for the bigger engines (with most builders who offer both engines, not just SL) is precisely €100k +vat.Zero extra fuel burn at cruise. If you can afford it why would you not?
Agree ^ .A few factors in this decision, not in order:
1. I like unique features at resale time.
2. I care very much about noise underway (part of the reason for buying a SL in the first place because they do FAR more noise management than any other builder in this size). The bigger engines will run at ~ 100 rpm less at any given cruising speed, and in my book that matters as regards noise.
3. Propellers will have higher pitch. In my book that will help a bit in tricky berthing.
4. On the very rare occasions I need top speed, I have a bit more of it
5. The existing shafts and gearbox that they fit with the 2200 hp engines can handle the extra the additional torque of the 2400hp, so new drivetrain engineering wasn't required
6. As mapism says, in #28
As for extra knots top speed, I'd guess 1.5 or 2.
Extra fuel burn = ~zero at any given cruising speed.
As for evolution up the HP tree, I see what you're saying but that's mainly a worry when you're running at WOT or same load factor in an "evolved" engine, compared with an earlier evolution engine. But I wont be - these engines won't change my cruise speed so I'm extracting exactly the same HP from the 2400hp engines as I would from the 2200hp engines, at cruising speed.
Admittedly I'll be doing that same cruise speed with more torque and less rpm at any given speed, so a 10% bigger bang inside the cylinders but those bangs will happen 10% fewer times.
BTW this isn't the top HP rating for this engine - it comes in 2600hp version as well. It's an incredibly well proven engine, absolutely the best you can buy in this class. We are talking 16 cylinders and 32 litres in a heavy 3.5 tonne engine of which tens of thousands are already in use - perfectly ok to take 2400hp max and 1600hp cruise out of that imho.
Great pics and info - but are they not V12s?Actually, by MTU, you mean Rolls Royce
I've just dug out my photos from my visit to the MTU Friedrichshafen factory.
This is a 16 cylinder CR2000 - I can't imagine the size of the ones you are having fitted
Yes, only the V8 (mine) has the twin turbo - all the others have triple turbos.
Anything bigger than yours, would have to be the CR4000 range.
I was told that CR2000 means 2 litres per cylinder (actually, I believe they are 2.2 litres per cylinder) - CR4000 means 4 litres per cylinder
CR stands for Common Rail, of course.
MTU also make an 8000!!!
Yep - I was about to change that post - you beat me to it.Great pics and info - but are they not V12s?
They look so easy to work on then we bolt them into a boat![]()
