gjgm
Tricky..How is the anchor supposed to be rigged through the rear roller then? A previous owner of my boat had tried running the chain over the roller, and when you launched the anchor, the impact of the chain on the edge of the anchor locker was a lot more than 3-5mm, it had worn away about 15mm (I guess because of the way the Delta launches). I re-rigged it the same as all the other T40's I'd seen - ie under the rear roller, and got the grp repaired.
If you try and route the chain this way with a bigger anchor it simply won't launch. If you're supposed to rig it over the rear roller - then what's the purpose of that roller?
Cheers
Jimmy
Well, looks like a new boat then, Jimmy !
