jimmy_the_builder
You're going to be doing a lot more anchoring in the Med than the UK, typically in depths from 4m to 20m so 30m of chain is going to be nowhere near enough. Also, typically, boat manufacturers always fit the minimum size anchor they can get away with. On a 47 footer, you should really have 60-70m of chain (largest size that fits your windlass) plus, say, a 25kg anchor or bigger (Delta seems to work well in the Med). Certainly when you're anchoring overnight as you will do if you want to make the best of Med boating, you don't want to be lying awake wondering whether your anchor is going to hold!
Hi Mike
The T40 is fitted with 8mm chain and a 10kg Delta as standard. I'd already decided to increase the amount of anchor chain that I carry (specifically for Villefranche!) but are you saying that I ought to go up a size with the anchor as well? Will a 16kg really make that much more difference over a 10kg? (Can't go any bigger that 16kg without changing chain size and presumably therefore also windlass). Boat is 41' long and weighs c.8t.
Cheers
Jimmy
