SUBJAG
I just purchased a boat in Miami with 2004 KAD300s DPX sterndrive. During sea trials the exhaust couplings ruptured and put out a lot of smoke. After this was repaired, the port engine would not start. All the belts were replaced at the same time. There was a couple days of standard troubleshooting stuff like replacing the fuel filters, changing fuel, etc. Fuel filters were replaced and finally the Volvo engineer was summoned -- fault code indicated a bad fuel injection pump. That was replaced, and finally the engines both started up. I also had a blower installed on a new circuit.
I had the boat trailered to Fort Washington in Maryland a week ago. I put both outdrives up before putting the boat down the ramp.
Both batteries were somewhat low, and engines would not start though they would turn over.
After charging, engines still would not start.
Separately, the starboard outdrive will not lower (but it will power up) and my Garmin chart plotter will not power on. But most of the electrical circuits seem to be working okay.
I sampled the fuel from the bottom of the water separator and didn't see any water.
Fuel injectors appear to have fuel at them (I had a general engine mechanic confirm this).
What should be my next steps to troubleshoot? Is there an instrument I can buy to pull codes? Are there any Volvo engineers nearby?
Thanks in advance. I was hoping the first day I owned the boat would be the best but it isn't working out that way...
