Adetheheat
What's the max wind speed I could sensibly go out to Sea in - assume that it's a Category A or B boat and so in theory could cope with stronger winds?
So many variables: upwind or downwind passage, tide with or against, sheltered water or open water with a long fetch ...........etcWhat's the max wind speed I could sensibly go out to Sea in - assume that it's a Category A or B boat and so in theory could cope with stronger winds?
This should do the job, Up for sale in Holland.What's the max wind speed I could sensibly go out to Sea in - assume that it's a Category A or B boat and so in theory could cope with stronger winds?
Yes that's what I've noticed.Unless you have an exceptional boat, or are particularly a glutton for punishment, a force 4 is about the limit for no pressure leisure boating. Even with a f4 it can still get very uncomfortable.
Which just proves how irrelevant wind strength on its own is as a guide.Yes that's what I've noticed.
I was coming out of Chichester harbour into open water, the tide was coming out of the harbour in flood and there wasn't a strong wind - Force 4 or below and the waves towered over the boat until I got within range of the isle of Wight after which it was flat as a pancake. I was very scared for about 15 minutes!
It's what the skipper can take rather than what the boat can...What's the max wind speed I could sensibly go out to Sea in - assume that it's a Category A or B boat and so in theory could cope with stronger winds?
The issue at Chichester Bar is generally waves, and the direction and speed of tide - wind is a factor, but not the major one.
Sea state is key. And that depends on local geography, and wind direction. Where the wind was blowing from and where is blowing from and will blow from.So many variables: upwind or downwind passage, tide with or against, sheltered water or open water with a long fetch ...........etc
You have to take sea state into account. Although the boat can take far more than you can, there's no point in frightening yourself silly if you can avoid it. I'm remembering a passage from Cap Breton to Bilbao.With motor boats only three things matter….the wind, the wind, the wind…
But the truth is that it doesn’t matter what the wind is like as you leave….only what it’s like on your return. If you can park safely then everything is good
