Greenheart
Excellent advice. Up to a force five Brie-z, she'll be steady as a Roquefort.
Of course not. We served an English Breakfast. Not some poofy chef-inspired fanatsy.I am not seeing any poached eggs on a bed of hot smoked salmon and steamed spinach on a English muffin smothered in hollandaise sauce..... or a short stack with fresh strawberries and whipped cream, accompanied by crispy back bacon and warm maple syrup from the Gaspe.....
So what boat would you choose to meet the following requirement seeing as the Macgregor is "the spawn of the devil !"
1/ trailer sailer
2/ beachable
3/ for a couple (in their 60s.)to have a holiday on as well as pleasure sailing
4/ clean inside and easy to clean as well
5/ ability to do canal work for long trip
6/ easy mast dropping single handed
7/ substancial room inside
8/ 6ft. headroom
9/ newish design
10/ between 10--15 K
11/ bearing in mind the canal/broads trips good motoring ability
12/ moderate maintainance
13/ ability in the sailing department limited
14/ SWMBO not the best of sailors
16/ store at home
17/ larger than 21 ft.
18/ easy to launch/recover
Velveeta to improve stability and give sustenance QUOTE]
Surely not?
1/ trailer sailer
The manufacturer's info says something along the lines of, 'can be easily towed behind a two litre family car'. I guess they had something like a Morris Princess in mind in 1981 perhaps, which I admit I really wouldn't fancy. A substantial tow vehicle would be the order of the day.
2/ beachable
Yes. (Actually the keel is part down and resting on the bottom in this pic to raise the water line to make a wipe round easy, but will float freely in a little over a foot.)
Yes.
If you clean it first and yes.
If you unstep the mast, which the manufacturers must think is easy enough as they suggest trailering the boat.
See above. May need a second pair of hands to mind a line and a gin pole to do easily and safely though as it's a proper size mast.
Yes.
8/ 6ft. headroom
Yes, aft at least.
9/ newish design
Not exactly new, but there haven't been any revolutionary advances since.
For an average one, yes.
Hull speed is about six and a half knots, so not much less than the 10 knots some say is the MaG 26's safe maximum.
No more or less than any other boat.
Yours or the boats?
Nice motion.
16/ store at home
Given a decent sized driveway.
26 feet.
Never tried, but I've no reason to see why not.
What, do you just pose with it on the trailer, or use it as an eccentric caravan?18/ easy to launch/recover
1/ trailer sailer
That is a lovely boat, and would say nicer all around (and especially inside) than the MacG, but the weight of the boat and trailer has to be around 2000 kg - I'm sceptical that a 2-litre car could tow that.
Its quite amusing to see the old advertising blurb for 70s and 80s trailer sailers.
Ours shows a ford escort hitched up.
Simon . Nice job on refurbishing. What size engine would you fit if you want to get home at 25 knots?.
2000 mexico?
[pedant] All Mexicos were 1.6L whether Kent or Pinto engined. The RS 2000 had a 2.0L Pinto.[/pedant]What size engine would you fit if you want to get home at 25 knots?.
2000 mexico?
There's another one for sale at a shade under £15K if you look in the usual places. Probably not quite as smart as ours, but may be worth a look. They would be a fair lump to trail regularly, probably needing a 4x4 to get a legal towing weight capacity. A believe a forum member, possibly Clive G, tows his regularly though.
Well, a whole can of worms opened up here !
1/ trailer sailer
2/ beachable
and several other requirements too many to list (without boring you)
