jimi
I'm horrified that Beneteau bolt a 2 ton keel to their hull with 6 or 7 bolts with just large washers on the inside. It would also seem that all the bolts are in line. Any lateral load must put tremendous loads on the hull GRP. Surely designers should allow for some grounding in a boats life because it does happen often. If the structure cannot take a typical grounding they will get a very bad press if keels fall off. Bavs first suffered loss of reputation, then Jeanneau by a keel coming off with hardly a touch and now it would seem Beneteau also.
My old boat has a big flange at the top of the keel . There are 6 bolts spaced at least 12" centres across the centre line and there is a stainless steel plate 1/2" thick 4" wide and goes right across both bolts which are at least 1" diameter. The flange is recessed into the hull moulding so it doesent add drag. So boats with bolted on keels can be designed strongly.
Just think what would happen to a car makers reputation if the wheels fell off if the the car hit a kerb at some time in its past. Designers have to allow for some misuse by the user. Someone ought to tell Bruce Farr!
If the Jeanneau you are referring to is the one in the Scillies, I saw that boat when it was lifted, there were a considerable amount of keel bolts in two rows all of which were bent and sheared. The boat must have been tanking along full speed when the bottom of the keel hit an immoveaveable object. IMHO it says more about the strength of the hull rather than the weakness of the keel bolts. The charterers of that boat would in my opinion have been guilty of manslaughter if there had been any fatal consequences as a result of them failing to report the incident. They were aware of what had happened and were able to say tell the exact location when subsequently questioned.
I'm wondering if there is any easy and cheap way to inspect the integrity of bolts other than by drawing them as visual inspection will not show anything unless its blindingly obvious.
