paulrossall
Was using my 15 month old JCB 240 volt 2000 watt grinder on my trailer and after a few minutes smoke started coming out of the angle grinder. Rested it a minute because I could not believe what I had seen but on running again smoke came out. It was only the third time I had used it, bought from Argos and just out of its 12 month waranty.
Next I used my 500 watt Black & Decker drill to put 13mm hole through angle iron at front of trailer to secure replacement tow hitch. Starting the second hole and drill slowed down and ... yes guessed right, smoke started coming from the drill. Thought maybee I had strained it but bit was newish, blacksmith quality, and was oiling the hole and drill was only slowing slightly until the smoke occured.
I then realised I was using an extension lead that said "not to be used for more than 1000 watt" because SWMBO had borrowed my industrial quality lead to watch television in the bedroom.
Do you think I buggered the grinder by having a big voltage drop and thus using more amps, and then buggered the drill for a similar reason?
I presume the drill is a write off (2 years old + well used) but what should I do about the grinder?
All advice welcome. Paul
<hr width=100% size=1>" there is nothing-absolutely nothing-half so much worth doing as simply messing about in boats".
