How many coats of antifouling paint
I use Hempel's A/F that is left over from the commercial boat when they do A/F so cheaper.
I use 20 lits for my 15-meter boat that gives me 2 coats and some for the water line chines and keel edges.
It generally lasts me 2 years but could go longer as the as the Hempel's has a 3-year life span on the fouling is quite light when pulled out after 2 years.
I generally pressure wash and the get 2 guys from the year to paint the anyifouling which helps the local workers
I agree with this. I got hold of some Hempel Olympic left over from a local fishing boat, about seven litres left in a 20 litre drum and a bit of primer all for £65, which I slapped on liberally. It worked well for two years and then a fair bit of weed started to appear but would drop off easily with regular use. The paint is eroding but you need to get up a decent speed (5 knots+) for it to work. It did 4 years and was replaced with the Jotun Seaforce version because I couldn't obtain Hempel this time. The Jotun is not as good at growth prevention but still erodes well so the weed comes off with use. I'd use either again.
I did an AF test comparing a dozen or so AF. I divided the hulls of our cat into vertical strips and applied each AF as 1,2,3,4, on one hull outside and then 12,11, 10 on the other hull, outside - and similarly on the inside of the hulls, 6, 5,4,3. I did the same for the mini keels and rudders. I found Hempel's Globic to be better than either of the 2 Olympic's formations. But its one of the products defined as to be only used by professional applicators and in commercial application (no idea why). Because there is a focus on commercial application the drums can be large (and impossible to lift, over the boot lip, into the back of a car). The larger drums need patience to mix - and a mechanical stirrer (I used a stirrer on a battery drill).
I found Jotan's Quantum Ultra to be the best and Globic a close second, Globic and Quantum might work slightly differently in a different environment., colder, warmer, more or less fresh water. International's offerings were adequate - but not as good. Because the 'free' sample I received of Globic was 'large' I then used it over the whole hill, when I had completed the trial and achieved a comfortable 2 years. The next time I used Quantum and also achieve a 2 year life.
My recommendation now would be based on cost, which was cheaper (Globic or Quantum) and similarly - availability. On availability a yard that handles commercial; vessels - fishing boats, would be my first port of call.
Jonathan
I have an idea why.
The environmental argument that prevents the sale of "professional use only" products with a far higher level of effective biocides to the leisure market doesn't stand up because if a few litres of such a product on a yachts hull is harming the environment to the point where it has to be banned then how are hundreds of thousands of litres of professional use only antifouling products on tens of thousands of ocean going commercial vessels not doing many times more harm to the environment and why aren't they banned from using it too?
The answer of course is money. Commercial shipping makes a profit which is taxable and a heavily fouled hull compromises that profit by both slowing the vessel down meaning the crew have to be paid for more days at sea and causing more fuel to be burnt to overcome the friction from fouling.
More fouling on commercial shipping - less money to be made.
In the leisure market the situation is reversed. Combatting fouling increases profits which are taxable for boatyards by forcing more and more leisure boaters to cough up for one or two mid season lifts and scrubs because the antifoul products available to the leisure market are becoming increasingly ineffectual and chandlers are enhancing their bottom lines by flogging more and more tins of the wretched stuff at at prices that go up every season.
More fouling on leisure craft - more money to be made.
Simples.
Not only is the dust a problem to the heath of you and others but antifoul removed must be collected in many marinas and disposed of in a responsible way.
I was surprised how much in weight could be collected. I used an old sheet below the boat.
I use wet scotchrite pads as that way you get no dust. Then I just slap it on until the tin is empty.
That is usually about 2 coats, which I can manage between tides sat on bilge keels.
I was pleased with myself when I managed it :) summer time.
A few things to consider:
  • By the time you remove the anti-foulant the copper/zinc content is only about 20% of new. Concluded from testing many samples of sandings and scrapings.
  • Any sanding/scraping dust is bad for your lungs, and in excess, can cause serious lung disease. Think of miners. So mask-up and use a vacuum sander either way.
  • Any sanding dust is bad for your neighbors. Always wet or vacuum sand, including fiberglass and topside paint. Metal grinding dust is even worse (leaves rust spots).
  • Non-copper antifoulants can be very good (I have one on my boat--Total boat Krypton, proven to 3 years), but the several agencies have held back on banning copper because they are not sure that other pestacides are not worse. Irgarol comes to mind. Same question re. human health. Maybe better ... and maybe not.
I did not go to copper-free paint because I am sure it is better for me or the environment. I write about sailing, so it was more of an expereiment. And it does keep the boat really clean--it was the number one paint in the prior test program.
I looked it up online. Well expensive! or did you get for nothing as you were conducting a test and writing about it?
I have an idea why.
Simples.
I suspect restricting sale of effective antifouls for professional use only is down to profit. The market for antifouling for large vessels is very competitive so margins are much lower than can be made with so-called leisure products. Jotun's Seaforce for instance isn't banned for use on leisure vessels, just that amateurs can't buy it so have to purchase alternatives at inflated prices = more profit.
Most of the above but at the end of the day plse do not dry sand in the yard without proper kit. Guy, two boats over from me doing an old boat now and its everywhere. Wonder how much of the first few coats are old lead foul. Bloomin nuisance.
I have always been very mean with antifouling quantity, but not mean with the quality. With a boat ashore every winter I have got away with one thinned coat all over of good stuff, not cheapest, then a second thinned coat a foot deep around waterline and on leading edges of keel and rudder. My objection to using more is the build-up: after 18 years of this, even with eroding antifouling and a light wet sand every year, I'm getting a bit of crusty-ness between thickness of AF and the places where it has flaked off because the first lazy person ever to AF the hull from new didn't degrease it properly!
I do not race any more but a sailing yacht should sail properly, and you do need a decent-ish hull surface.
Sooner or later I'll pay for a grit blast and start again, maybe with Coppercoat, even though it's effectiveness as AF may be less than Micron or Seajet 33 it does look easier to clean off. I just wish a local yard would do the relatively cheap mid-season scrub offers available in the Solent.
