Tranona
Despite all that, even though many of the smaller 30-33' AWBs like the Hanse discussed here were offered with the option of tiller or wheel (at extra cost) and almost universally buyers ordered them with wheels. So clearly those that buy the boats have different views from those that don't!They do, however the set-ups are frequently awkward (this is the polite version) and most often have to overcome the friction and resistance of the primary steering mechanism. They are after all, in this instance, considered an emergency back-up.
I have to agree with Johnalison here, under 40' I would consider a tiller to be the preferred steering system. It doesn't prevent you having a below deck autopilot either, doesn't require a rudder indicator, doesn't leave you in any doubt when you need to fix your sail balance for optimum performance, is superbly responsive and you can hold it between your knees as you sort out the main sheet or hang on to your cuppa. In port you hinge it up and it's out of the way whereas some owners of wheel steered boats remove the offending device so they can move about freely or have one of those (wobbly) folding models.
As to emergency tillers, they are indeed difficult to operate, but that is little to do with friction or resistance and more to do with limitations of space to use a long enough tiller to deal with the loads of large high aspect ratio rudder. As for responsiveness you have clearly not experienced modern boats with high geared steering. As for holding between you legs, why not just press the autopilot. suggest you read the reviews of boats with wheel steering (just about all of them these days) and they invariably comment positively on the feel and responsiveness of the steering. Things have moved a long way since wheels started to appear a boat sizes increased and a lot of the old fashioned prejudices no longer hold.
