Hi,
Any suggestions on sorting a worn stanchion?, some sort of wrap around sleeve?. Cheers DB
Time for a new one or have it welded. There's clearly very little metal left.Hi,
This. It's done. A serious welding repair at a minimum. Grind out and weld the crack. Fill the hole (or at least the wear) and re-drill. A new one, if available, would be cheaper.Is the stanchion cracked in the lower left of the hole ? as well as worn ...... if so - over here - I would make a trip to a metals guy to see if he can repair.
