penberth3
No. That bit need a centre.
My guess is that it would grab in the plastic quite forcibly, most wood drills are designed to kind of knife around the perimeter of the hole to cut the grain tidily.
Thanks for everyone who responded to my query. The comments were very helpful. I am happy to relate that, for my purpose, the way that worked very well has been:
1) wedging in a piece of softwood (spruce?)
2) drilling a small pilot hole in the centre
3) using this (relatively cheap) drill bit
ARMEG WOOD BEAVER 4-FLUTE WOOD DRILL BIT 165 X 32MM (91676)
from Screwfix on a hand-held drill.
My favourite way too, mostly ignored.Since I have a 32mm hole saw (yes, Starret) and my step drills don't go that big, I'd nick a trick I saw on AvE's channel.
Get a piece of scrap ply and use the holesaw to make a 32mm hole. Screw it/double-sided tape/just generally bodge it onto your workpiece and use it as a guide to make the new hole.
Post 14.I need to re-purpose a circular hole in a GRP vertical cockpit bulkhead to take a new instrument but it needs to be enlarged from 1 & 3/4" to 2" so beyond filing. Obviously can't use a hole saw as nowhere to centre it. Thought of using a Dremel to grind it out or possible having a go with a power jigsaw. Think a multi-tool cutter only cuts in straight lines so not much use.
Any ideas?
If the grp is not very thick, a drum sander is very effective. Because it sands along the edge, it doesn't flex the panel. It doesn't chip the gelcoat.I need to re-purpose a circular hole in a GRP vertical cockpit bulkhead to take a new instrument but it needs to be enlarged from 1 & 3/4" to 2" so beyond filing. Obviously can't use a hole saw as nowhere to centre it. Thought of using a Dremel to grind it out or possible having a go with a power jigsaw. Think a multi-tool cutter only cuts in straight lines so not much use.
Any ideas?
I'll try that - the Dremel has attachments like a mini drum sander.If the grp is not very thick, a drum sander is very effective. Because it sands along the edge, it doesn't flex the panel. It doesn't chip the gelcoat.
Might ask , is it a Blind Hole or an open ended hole ?
There are Hole Borers that are steped in incrimental sizes , they are sold with the Step Diameters stated ;......
A drum sander set from screwfix or toadstation did it for me,I'll try that - the Dremel has attachments like a mini drum sander.
The piece of ply goes in front of the panel, and doesn't so much create a false centre as a false circumference into which the holesaw fits.Remember you'll be making a lot of hazardous dust.
I'd use a coping saw with an abrasive blade, or a pad saw. Or as suggested refer back to Post #14 - fix a false centre behind the panel.
It's an open ended hole but there is an air gap and then the thin GRP interior panel (also need to enlarge that to same dimensions) so can't really access the inner face. Coping saw wouldn't work and pad saw would probably make a mess of the edge.
