Enlarging a hole
Like this; need to enlarge inside skin by maybe 4mm diameter outer skin more like 8mm diameter increase. Both layers about 3mm thick
The standard answer to enlarging a hole is to fill it (tap in a suitable sized piece of wood) and re-drill with a suitably-sized holesaw. With such a small increase you'll have to be careful to start accurately on centre, though.
+1.
Did this successfully when changing Depth transducer on my Dehler a few years ago.
you can put 1 hole saw inside another one , then the 30mm will keep it as a guide and entered , then the bigger one will cut ?
