PaulRainbow
I was thinking that you were suggesting a much cheaper option than a B2B or thick cables, so as I read it I was expecting you to link the VSR to the windlass motor power supply so only disconnects the charging cable when the windlass is actually letting out or hauling in chain. I thought, “That’s really neat”, but then realised I’d misunderstood.
As an example in my setup the engine battery is only ever charged by the motor running. Solar and very very occasionally shore power charge the house only.
My bad for assuming the engine battery was charged by means other than the alternator. Still a few ways to achieve the Ops desire of a cheap solution.
If the engine battery gets charged by other means, post #11 is sound. If not, a pair of normally closed relays can be fitted in series, so the VSR negative passes through both relays if the are closed, if either opens the VSR opens too. Then connect the relay coils to the windlass control circuits, one to "up" and one to "down".
It would also be acceptable to connect the VSR to the domestic bank, using the relays as above. This would allow the windlass battery to be charged by any other charging source connected to the domestic bank (in your case, solar or shore power).
