B27
I think with a sailing boat going slowly, there may be some gain using one engine, because the second engine would be using fuel if it was just idling, driving its water pump etc etc.The power that is required to drive a boat through the water is a function of the hull shape and a function of speed through the water.
The power developed by an engine to obtain the speed is mainly a function of the amount of fuel consumed and this can/ would generally be the same if supplied by a single engine or multi engines it the power that is consumer.
There is an efficiency factor which will affect the total fuel consumption.
You have the basic efficiency of the engine / prop / drive chain.
If you use a single engine/prop/drive chain, there could be a difference in efficiency when using twin engines
But maybe less so if that means there's big fixed prop acting as a brake and trying to may the cat go around in circles.
It might be something to look into if the OP ever gets becalmed on a long trip.
