PaulRainbow
If they are both connected to the same battery each alternator will sense the output of the other alternator, this can cause an issue, depending on the alternators.I don’t really see the difference between having two alternators connected in parallel to one battery, versus having two alternators connected to two separate batteries connected together via a Cyrix relay.
If each alternator is connected to a different battery it will only sense the terminal voltage of the battery (again, depends on the alternator, to a degree). When the VSR closes it will parallel the two banks, but they will still have different terminal voltages, depending on the state of charge of each bank. When they both reach the same terminal voltage, or thereabouts, one alternator might reduce its output, as above, but as the batteries will all be mostly charge it isn't likely to matter much, as the batteries aren't likely to be able to accept the full output of one alternator.
To a degree this will depend on the alternators, the batteries and their state of charge.
