GetItDone
New Member
Hi all,
I need to replace the house battery on my 23ft Pegasus. It came with a 75ah Lion brand lead acid which has, being a Lion, died very quickly and won't hold a charge despite spending a week and a bit on a reconditioner.
So, I'm thinking that I would like to increase the capacity of the batteries onboard so I can comfortably run the nav system, radio, lights, and a USB charger without worrying too much about it. We've got a solar charger on the deck roof which provides a steady charge, and the engine also charges from the tiny alternator when it runs, both fed through a voltage sensitive relay.
Currently the batteries are installed out of the way but in a place that makes them quite hard to get to, so I think I'm going to re-locate the leisure battery under the cockpit behind the engine which should make it more accessible. This also provides the space for more battery capacity.
My current thoughts are to go with a 115-120ah deep cycle battery to replace the current one, which will surely be enough to keep all of our needs up and running when doing cross channel excursions etc. though I would appreciate input on that.
The problem I'm facing is there are so few good quality true deep cycle batteries out there, and the ones that are tend to be extremely expensive. Does anybody have any recommendations for good, reliable, reasonably priced brands?
Many thanks and all the best!
