Ammonite
I currently have a house bank made up of two 105ah SLA, a 105ah SLA starter battery and an AGM for the bow thruster (I can't recall the capacity but it works well). Everything is set up for 12v. I also have 300watts of solar charging the house bank and a Cyrix battery combiner between the house bank and the AGM. The setup works well although it would be great to have a larger house bank.
With this in mind I'm planning to upgrade the house bank to LifePO4 at some point and when I do this I was intending to split the solar so that 100w goes to the starter battery and 200w to the new house bank, with seperate Mppt controllers, and to move the Cyrix so that the starter battery charges the AGM. I am also planning to install a 50amp Victron DC-DC charger between the starter and house bank suitably derated so that it doesn't fry the 70amp alternator, which I may also upgrade in time.
Does it make sense to split the solar in this way and once the starter and bow thruster batteries are charged how efficiently will the 100w of solar going into the starter battery charge the house bank via the DC-DC charger. I don't have shorepower on my mooring and I use the bow thruster a fair bit getting on and off the mooring, hence the need to charge the AGM via solar before the next trip. Thanks
Edit: I don't think it's relevant to my specific question but for context the three banks are also charged by a three output mains charger and the alternator via a three way splitter. Both of these connections will be removed from the house bank when I fit the LifePO4
