thinwater
Sand is nearly as variable as mud. Coarse, light coral sand and fine mineral sand with a little mud are worlds apart. The later generally sets in a few feet and will break the chain with some anchors (done that).
In the real world:
* Undersized Delta in super soft mud. It was simply overpowered.
* Fortress barely set in hard send/shell. It released with the tide reversed. Fortuantly, I was on-deck, only a few minutes from raising anchor anyway (I didn't trust it).
* Danforth on a wildly yawing catamaran (no bridle, main sail up). This doesn't even count.
During testing (no counting anchors I overpowered, which is nearly all of them)
* Obstruction lifting chain. A stick or limb that guides the chain to the surface.
* Clogged roll bar. Either sticks or weed.
* In-line tandem. The secondary always trips the primary in a shift.
* Hardpan hiding a few inches under the sand.
* Pulsation with waves, particularly at short scope. This can reduce holding 2-3 times in soft mud compared to a quiet anchor. The soil cannot consolidate. I suspect this is a common reason in squalls in crowded anchorages; the anchor was set at short scope with a steady pull. Then the boat starts pitching and bye-bye.
In the real world:
