greeny
Looking at "new to her" boat for a friend and noted that on the Domestic battery setup she has 2 batteries under the quarter berths, one port and one starboard. These are paralleled with hefty battery cables to create the "bank". Ok so far so good. Then I see that the solar panel system is connected to the positive on the stb battery and the negative on the port battery. The 12v main distribution panel is fed from these batteries , positive from the strbd battery and negative from the port battery.
This wiring, like much of the other wiring, is very untidy and the routing of them could be much better. So plan is to do a wiring replacement on these wires and reroute them at the same time.
The question is, what is the perceived wisdom of splitting these feed/supply wiring this way? Is there a real advantage in doing it this way? We would prefer to just take the connections to the port battery as it cuts out a lot of re routing and cable length. With the large battery cable links that are used to parallel the bank I can see no difference electrically to where the feeds are connected. Or am I missing something?
