D
Deleted member 36384
I have given up trying to explain why and how it works. You, I and some others here know why and how because we have used it and seen it being used. If others, who evidently do not understand the principles of the method, are happy to live in a fantasy world where all berthing lines are always soft and are never under tension, then good luck to them... and to whoever has berthed before them and was first to use 'their' bollard.
That is because you cant explain it to be different from just dropping your line over. Your functionality caused by dipping, even leaving the back of the loop on top of the first line, offers no additional advantage. It is you that is living in a fantasy world. Tension is irrelevant, it is a different problem that requires a different solution. I wonder just how much sailing you have done in different ports, in different boats, in different conditions. You demonstrate a level of ignorance commensurate with someone with little practical experience.
I used to think the same as you but I was wrong, I have learned that I was wrong and practical experience has demonstrated that my logic is both valid and practical in the real world. Dip away Puff, it is of no consequence to me, but you are wasting your time feeding loops up through other loops before dropping over the bollard or cleat.
