Dare I mention Soltron
Do you think its time to set up a separate forum especially for the discussion of Soltron. it seems to be the main topic of conversation on MBC although its as difficult to find as Osama bin liner.
stuartw
30 May 2001
Berkshire
yes I dare!
I bought some last year via the internet direct from the States. Although cheaper than obtainable from UK, the 32oz bottle arrived leaking and 2/3rds full. A loose cap and flimsy packaging contributed.
As to it's claims - next question. I am very sceptical. There maybe, just maybe some bactericidal effect on the fuel, however as to improved performance- no sign of it so far.
No, despite the claims of, I believe Belfast University, I have found no benefits whatsoever.
So my advice- save your money- unless of course, somebody else knows different.
DepSol
6 Oct 2001
Guernsey
Re: yes I dare!
Yeah had a freind who did that saved 85p over all and it wasnt the same stuff looked a bit greener in colour probably peed in the bottle as they knew he wouldnt return it!!!
Freebee
21 Oct 2001
Alton, hants
Re: yes I dare!
If it is a bacteriaside or fungiside its base may be similar to products used in aviation fuel which are ether/alchol based. They kill the bugs by raising the osmotic pressure and hence the little blighters get fat and explode. This is why dead bugs plug filters. If these products are ether/alcohol based then they will slighly change the fuel flamability and burn characteristics but the change will be miniscule compared to what might be claimed.
Bugs can only exist in fuel if there is a water bottom, the bugs live in the water and eat the carbon out of the hydrocarbon fuel.
Best advice is to remove tank water bottoms- but in boats that is not easy, on hot summer days tanks breath in the humid air as fule is consumed and at night as it gets cold moisture condenses and drips into the fuel in the summer this is a daily repetative cycle.
jfm
Jersey/Antibes
Re: solly\'s method
Mike, to be fair it doesn't claim to be a fungicide or bactericide, which merely kill the bugs and leave their corpses in the fuel. It claims to be an enzyme which digests the bugs, AFAIK
JFM
Get it in UK
To obtain Soltron quickly and securely in the mail, call 02890 471006. This number is in Belfast and is Soltron/Solpower Ltd.
