lustyd
On our boat that's also true of the sofa so it makes little difference either way. People who don't shower are dropped off at the nearest port!
We already had a smaller high build quality well equipped yacht ten years ago.No, but if you'd bought a smaller boat 10 years ago you'd have had to upgrade the boat and start the process again on a bigger one.
OP seems to be able to afford either option so depending on the scale of the upgrades it makes sense to do it all once and take the small hit on mooring fees. I've spent probably £20k upgrading and updating mine so it would have been madness to do that twice in order to save £1000/year on mooring.
To recap, I bought my current 40' boat as my first.One thing I did consider was if in mast furling is a good idea. Obviously for me it will mean not having to go on deck.
A few of the SO's I have looked at online have this. Every boat I have had with a stack pack, the sail battens get caught on the lazy jacks and I end up flapping around trying to free them.
..... I'm a little surprised that at least one experienced member of the forum thinks a furling main beneficial.
I have sailed 10,000 miles both with in-mast and 10,000 miles with a fully battened main and Lazyjack system as a long distance sailing husband and wife team.
The battens were always catching on the lazyjacks and I had to go forward every time to reef. No such problems with the in-mast. It got a bit stuck on a handful of occasions, but no dramas and easily rectified.
I prefer the in-mast for ease of use.
If I was interested in performance then perhaps battend main on roller cars with everything led back to the cockpit would be ideal.
I can't speak for e sail sizes on the Jeanneau. My boat is also brand new - a Rustler 44. Interestingly, the main on the in mast
Rustler 44 is actually bigger than the main on the conventional cutter rigged. My understanding is that this is to do with balance.
We have as much roach as is possible. To be honest, any more and we would be hitting the backstay. With proper sail cut and strong battens I think there is quite enough stiffness.
Having said all that, I think the decision for this type of rig is really down to handling preference. There are so many of both types that they both clearly work. The differences are very small.
All I know is that I much prefer in mast. The sail pops out in seconds with virtually no effort, and one person can furl it in about 20 seconds. No lazy jacks to get caught on. No stack pack to zip up. No cover to put on around the head of the sail, no reefing lines hanging in the cockpit.
I am definitely a convert.
I sail an Amel Maramu (49') from time to time and it has in-mast furling and electric winches. It's a delight when short handed.
I certainly wouldn't add to the potential for things going wrong by having a roach and the vertical battens to support it.
With the relatively small, high aspect main on a modern boat I don't think the loss of drive is significant for a cruising boat. I'd certainly consider in-mast furling on my next long distance cruising boat.
I have an older Bav 46 with inmast furling... as stated above, the larger Genoa makes up for the reduced mainsail size nicely. My main/genoa 150% lasted 13 years and I have just replaced them; looking forward to sailing faster in lighter airs... Furling reduces the work considerably for short handed crew (GF and I).
It may depend on what particular make of furling gear you have. I find my (Kemp / Selden) gear very easy, and don't have any of your problems.
Or again, it may depend on precisely how it's rigged. I had never had in until my present boat, and for cruising, would recommend it.
Done 4 transatlantics with furling, 6 without.
I like it and I reckon it makes the boat generally safer.
Well personally on a 57 foot boat I would'nt like to handle a slab reef main without a cockpit full of gorillas! If a family boat then there's only one option, IMHO, and that is in mast reefing.
Not sure why you are surprised. Post#45 gives some specific examples of other forum contributors and of course I have often explained why I think it is superior for a cruising boat. Another little nugget is that over 90% of HRs above 36' (and many of the smaller models) built in the last 40 years have in mast. In fact it was HR that pressed Selden to develop and refine their system to meet the expectations of HR customers.It has a conventional mainsail, with slab reffing - this is not a concern at all to me, and I'm a little surprised that at least one experienced member of the forum thinks a furling main beneficial.
No, I just think the hassle is not worth caring about. It takes a few minutes to put the sails up, compared to the hours spent cruising. If I'd got a boat with a furling main I would probably be perfectly happy with that too. This strikes me as one of those things that some people are (probably pointlessly) religious about.… - plus of course defend it because you don't have a choice.
In the interests of balance, I'll just say that when things go wrong with in-mast, it can leave you in a nasty situation. It's almost impossible for a slab reefed main to get stuck, …
The same argument could be made against roller genoas, except in that case you can manually wind the sail around the forestay, by driving in circles if necessary. No such option exists for the main....
Good point. Curious about how this happened- do you use a skinny dyneema halyard? Is the sheeve a bit worn and loose?They get stuck when the halyard jumps the sheave and jams in the truck.
It has happened to me twice and both times required a mast climb to release the shackle. The last time was in an Atlantic swell off Vigo, not easy and very risky.
Anything can fail.
Can you list the "large number of disadvantages" as I seem to have missed those. On the other hand you seem to have missed all the positives that others have listed.Yes. Of course modern roller genoas have a large number of advantages and a few disadvantages. Furling mains have a large number of disadvantages and the single advantage: ease of reefing.
Fine for the sort of sailing the OP has outlined.
So not an issue with in mast furling after all.The wrong shackle had been used
An installation error by the yard. Having a few threads protruding on your halyard shackle wouldn't have the same consequences on a slab reefing system.So not an issue with in mast furling after all.
It's not far off of the issue Ruby Rose 2 had recently where a lack of threadlock made a screw come loose and caused their unreefed slab main to stick at the top of the mast.Having a few threads protruding on your halyard shackle wouldn't have the same consequences on a slab reefing system
