Battens fouling lazy jacks when hoisting main
Ticoda
19 May 2013
I have a Westerly Tempest with a fully battened main. The problem I have is that unless she is right up to the wind when hoisting the main the ends of the battens foul the lazy jacks. She only has to fall off a couple of points for the main to catch the wind and the problem occur. Has anyone else had this problem and if somehow did you fix it.
Andrew...
pampas
17 Jul 2003
Falmouth
Two ways, keep them tight when hoistig or fit two down hauls via mast slacken Jacks and pull down haul thus bring Jacks clser to mast. YOUR CHOICE!!!
skip50
4 Jan 2011
Troon
I agree with the OP, you have to be pretty much exactly head to wind when hoisting. I get the helmsperson to watch the battens etc and adjust their course as necessary. I am usually doing the donkey work.
I still wouldn't be without the lazy-jacks and stack pack, or whatever mine is called.
Just seen bobc's reply, mine don't stick out past the leach.
theoldsalt
24 Nov 2010
Bristol
....or remove the lazyjacks completely. I did on my Moody, they were a menace.
The disadvantages when hoisting the main outweighed the advantages when lowering the main.
oldbilbo
17 Jan 2012
West country
We had the same problem. What we do is let the lazyjacks go completely slack and that way they do not catch. Once the main is up we re-tighten the lazyjacks
Endorse....
A technique I found effective was to free off the mainsheet so the boom swung permitting the mainsail to feather, then hoist the sail until a batten caught on a lazyjack line, then ease the sail down a few inches until the light flogging and/or slight change of heading made it possible to haul the sail-and-batten up clear past that snagging-point. Then haul up some more until the same thing occurs to a different batten....then repeat the process. That took a few moments longer than a clean straight hoist, but never failed or caused further problems.
johnalison
14 Feb 2007
Essex
This can happen with us. My way of coping is to steer slowly into the wind with one leg each side of the tiller to helm and pull on the main halyard with my hands. This way, I can control the hoist so that a snag is unlikely and drop the main a bit if it does happen. Oddly, it can often be easier with more wind, since the flapping sail tends to free itself.
An unsatisfactory alternative is to set the lazyjacks up after setting sail.
Halo
10 Nov 2009
Wetherby
Endorse....
+1 this is what I do
Incidentally putting in thinner reefing lines has made mainsail hoisting much easier
jdc
1 Dec 2007
Falmouth
Try hoisting the jib first
I think we all have similar issues, and while the palliatives mentioned above work to some extent, none are perfect cures. The root of the problem is that when motoring directly up-wind the mainsail is pretty poorly controlled. This has not only the drawback of the battens catching on the lazy-jacks but also:
- the air flow is unstable (so they're more likely to get caught)
- the boat has to be steered dead upwind, +/- almost nothing
- the sails flap and it's noisy
- it's maximally dangerous as the boom swings across the cockpit
- it can only be done under engine.
In contrast if you hoist the jib first, go onto a close reach, let out the mainsheet and then hoist the main:
- the airflow from the jib is laminar and steadies the mainsail
- the boat can be luffed or borne-away while still under control and yet the main still goes up without snagging
- the sails are silent
- the slight heel and the airflow both move the boom out of the cockpit
- it can be done without engine.
So my suggestion is to give this method a go and see if you get on with it; I think you may never go back to the old method! I found it a revelation. The main goes up without fuss and catches a lot less frequently, plus it can be done singlehanded.
Plevier
22 Aug 2008
Brighton
What an interesting idea - will definitely try that!
Helps a bit on my boat that the lazy jack lines go to partway out on the spreaders, not to the side of the mast.
Dipper
30 May 2001
Dorset
I had lazy jacks fitted over the winter. I don't have a problem with the battens but my headboard starts flapping vigorously just before it clears the top of the lines and gets caught. I'll have to try setting the genoa first and see if that helps unless anyone has another good idea how to stop the board flapping or how to temporarily increase the gap between the lines as I hoist the main.
maby
12 Jun 2009
It is - and seems to make sense - will definitely try it the next time we go out - thanks!
ianfr
11 Jun 2007
Colchester, boat Tollesbury
picasaweb.google.com
I have lazy jacks fitted with a downhaul.
When hoisting I release the uphaul, pull in the downhaul, leaving the lazy jacks lying along the boom.
Reverse when dropping the main.
Works for me, takes 30 seconds.
PM me if you want a diagram.
Regards
Ian
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
I had a new stackpack made by Crusader and they only have 3 points of attachment for the lazyjacks. The aft one is further forward than the old one and I therefore get less snagging. Try adjusting the lazyjacks so that they are lower at the aft end - most of the work they do is on the forward half of the boom.
25 Feb 2010
I keep promising to reposition the upper blocks of the lazyjack to the spreaders so that the lazyjacks form a "V". One day I'll get round to trying it.
Houleaux
29 Nov 2009
Solent
I use both of these methods and they certainly make life easier. I also leave the clutch open when hoisting the main (my main's not too heavy to do this) which means that it's easier to lower the sail a little to free any snag and then quickly hoist again once the sail is free.
