steveallan
Thanks to everyone for a really entertaining evening. Much better than watching a old DVD.
If anchors are really good, why should any parts ever need replacing?
Glad we are entertainingThanks to everyone for a really entertaining evening. Much better than watching a old DVD.
By the way, our warranty covers ALL damage, no matter how it occurred. We never even ask customers that question.
The most offensive post on this thread has been #128.
I also enjoy Craigs contribution to this forum, and Brians and the chap from manson...
Broke what Rocna? I have never seen a shank-to-fluke weld on a Rocna break. It is one of the strongest parts of the anchor. There is a vicious little rumor out there put forth by certain interests that posits there is some issue with welding steel to cast steel. This is an outright falsification from people who should, but admittedly probably don't, know better. Whilst involved and requiring careful specification and quality control, there is absolutely no issue whatsoever in this process as it is spec'ed by Rocna. It is very standard, done according to industry standards - not to mention IACS/RINA materials & welding specifications.
If you load put a Rocna in a test rig and load it up until you start breaking things, you will eventually firstly bend the shank, then probably the fluke, and if you're still able to apply force to it probably finally rip the rode attachment point out of the end of the shank. All before the shank-to-fluke weld is ever troubled. In the real world of course with matching gear you'd have long since busted the shackle or chain.
On the Manson fluke above. Manson use this method of construction with a few of their anchors; a required shape is made up by edge welding thinner plate together, rather than using solid steel or proper casting set-ups. Specifically in the case of the Supreme, they copy the general configuration of the Rocna fluke which has a thicker tip (for strength and tip-weight) and a thinner heel (to save weight where the strength is not required). The Rocna uses solid steel, whether fabricated or cast, in both areas. Manson however make up their fluke by welding face-to-face two thin sheets of steel, the smaller portion forming the thicker tip.
It is a basic mechanical engineering principle that the strength of a beam of steel is proportionate to the square of its thickness. In other words, a beam (of the same overall dimensions and material) that is 10 mm thick is 4 times the strength of one which is 5 mm thick.
When you take two 5 mm thick sheets and put them together face-to-face, you have the sum of their respective strengths, which of course is 2 times (not 4 times), in this example.
The edge-weld then adds some more strength back into the set-up, but it should be plainly obvious that a thin edge weld, which leaves the interior completely untouched and hollow, is not going to bring the fabrication back up to the strength of solid steel.
Manson falsely use the term "laminate", which of course relates to gluing sheets together to make things like plywood. Laminate structures like that benefit from their make up of glues and crossed grains to greatly increase strength - but this has nothing whatsoever to do with edge-welding two sheets of steel together to fake a solid looking product.
Rocna's Lifetime Warranty section. It is only for the original purchaser.
So a no on the warranty question.[
Would anyone ever warranty a 20kg item, when if a 15tonne boat locks it's chain off and drives the anchor out and expects there to be no damage??? This wouldn't really be commercially practical. Because Fortress can replace parts this is far easier, it isn't a fully welded item.
Given that the opposition offer such a warranty and have questioned the construction methods of the Supreme it would seem to be an opportunity missed.
I do ,however, appreciate your straightforward answer.
Noelex, I would check the Rocna warranty write up before concluding that they would cover damage in that circumstance. There is a lot of legalese and exclusions. Maybe another question for young Craig on his ever growing list.
I understand it is a difficult issue. When an anchor is bent the user will claim perhaps it wasn’t strong enough and the anchor manufacturer will claim no anchor can survive undamaged in all conditions.
I do wonder if this is the correct commercial decision. If only 3 Supremes have been bent in 20,000 it would be inexpensive to cover the damaged anchors even if it was viewed as a form of insurance, or good will gesture, rather than a strict warranty issue. Given that the opposition offer such a warranty and have questioned the construction methods of the Supreme it would seem to be an opportunity missed.
