Your favourite compass.
RupertW
20 Mar 2002
Greenwich
My favourite was on an old wooden boat my Dad owned. You just turned the parallel lines to the exact course you wanted then to steer you just had to stay between them. Instantly intuitive and very restful compared to “Steer 75 degrees” on a modern compass
Refueler
13 Sep 2008
Far away from hooray henrys
Reminds me of the 'Aircraft Compass' my father had on our boat ... same idea ...
damianod
22 Aug 2010
I liked the Sestrel one that came with my first boat. I could understand the correctors, which consisted of bars that you could add, and managed to correct 14 degrees deviation from the bracket of a fire-extinguisher that I mistakenly put on the other side of the bulkhead.
I would have moved the fire extinguisher...
GHA
26 Jun 2013
Hopefully somewhere warm
Without a doubt favourite! :cool:
DSD TECH MPU-9250 9 DOF 3-axis gyroscope, 3-axis: Amazon.co.uk: Electronics
Kukri
23 Jul 2008
East coast UK. Mostly. Sometimes the Philippines
Sestrel Major Compass. I have sailed on two boats with them fitted as standard and my own boat has one. Nice and large, easy to use, well damped. Last year I had it professionally adjusted and it was not that far out. They are not made any more but can still be rebuilt if that is required. The needle can wear on the pivot and stick when healed over, but I have not seen this.
My hand bearing compass is fantastic to use close up, well damped but the light has faded from it; unfortunately I can not remove the name of it.
Definitely the Sestrel Major, for the reasons given and because it is infinitely repairable. Now as scarce as hen’s teeth, because the RNLI buy any that come on the market and get them rebuilt by Barry Phillips… enough said …
Barry rebuilt the Sestrel Brytlit hand bearer that I bought in 1973 and was able to replace the tritium capsule.
All Sestrel compasses are well damped but the damping in the Major is outstanding . No matter what the boat does, the card just sits there like a rock.
andsarkit
27 Aug 2015
Dartmouth
This is the original Mini Compass that I have from about 40 years ago. I think it was copied by the Iris 50 which uses the same principle of projecting the readings onto the horizon.
I'm also a fan of the Bosun grid compass except once after being becalmed and drifting for half a day I set off 180deg in the wrong direction when the wind returned.
Tranona
10 Nov 2007
My Eventide (1963) had the full set of Sestrel Moore (complete with pelorus) for main steering, Sailing Grid under the tiller and Radient hand bearing. Moore went with the boat, still have the other 2 in the garage!
