Window disaster
pugwash
30 May 2001
SW London
Have just renewed the cracked and splintered perspex in my doghouse windows and what a delight it is - l can actually see out.
Last weekend I wielded the varnish brush and in a perfect drying wind managed to do everything until the rising wind blasted thistledown off the fields. But this was not the disaster.
Just before sunset I went around the boat with window cleaner. They needed a bit more buffing up so I grabbed the J cloth.
This was the cloth i had used while varnishing and it was lightly impregnated with No 1 thinners. Result: murky marks that can't be rubbed off. There is no warning on the tin and I have used thinners in plastic mugs so it never occurred to me that there would be a problem with perspex (not that I thought about it at the time, it was just a handy cloth).
But a problem there is. The starboard side windows are ruined by swirly rub-marks impregnating the surface. Horrible.
Does anybody know a treatment? I wondered if perhaps T-cut or similar might be used or would this make the problem worse? Any thoughts?
Thanks.
longjohnsilver
30 May 2001
Thanks.
I had a similar problem when using acetone to clean silicone sealant off perspex. Had to use very fine wet and dry and then a rubbing compound to bring it back to as it was. A bit time consuming but not a difficult job.
cliff
15 Apr 2004
various
"wet & dry" to remove the marks and smooth the surface - start with 240 or 320 grit and work up to 1200 grit - clean well between changing grits. Finally, Farcla G3 and a slow speed polisher with foam head and buff to a clear finish.
awol
4 Jan 2005
Me - Edinburgh; Boat - in the west
Not for the faint-hearted and should be practised on scrap bits first - application of heat by blow torch or heatgun; a cook's brulé torch is good. Get it right and you can restore the gloss if not the optical clarity - linger too long and you are definitely re-glazing.
snowleopard
Oxford
Various treatments are available but the most straightforward is Acrylic Polish (google it). You'll need a lot of elbow grease but it will eventually do the job.
Others that have been suggested include 1200 wet/dry used wet with coal tar soap. T-cut and International gelcoat polish may also work.
V1701
1 Oct 2009
South Coast UK
Another one to try is Meguiar's Plast-RX, did a good job on cloudy plastic sprayhood windows for me. Possibly not abrasive enough to use on it's own but for the final stages?
Sandyman
2 Jun 2007
Thanks.
What is a ''doghouse'' ??
lenseman
3 Jun 2006
South East Coast - United Kingdom
www.dswmarineengineering.com
Toothpaste very good, as are some of the other 'polish' suggestions BUT 240 or 320 Grit Wet & Dry is far, far too course! 1200 Grit is the absolute maximum coarse Wet & Dry paper I would try suitably 'chalked'. Better to go 1600 or Crocus Paper and then rub "Oh So Gently" if going down this route!
CROCUS PAPER HERE:
http://www.m-p.co.uk/muk/parts/chap10/0482000115.htm
Always try a very small area on a side window first. ;)
MissIsle
16 Jan 2011
Fareham
The best & most thorough way is to go through the grades with wet n' dry. start at 600 & go down, 800, 1200, 2000, use washing up liquid as a lube for an even finer surface finish. Then T-Cut & finally polish with a fine automotive polish or jewlers rouge. I would work by hand as acrylic melts at arround 65ºC & a polishing mop can reach that.
There is a quicker fix if it's not the main screen. de-grease the screen with soapy water & dry. Then spray it with a clear air drying "ACRYLIC" lacquer. If you are any good with a spraycan it will be clear & see through, & you won't tell the difference unless you get right up to it. But make sure it's acrylic lacquer. You can even get tinted lacquers if you want.
lenseman
3 Jun 2006
pugwash
30 May 2001
SW London
Thanks for all those neat suggestions. I had no idea it would be so easy. Elsewhere I found a suggestion for Brasso which might work. I'll get busy at the weekend, knees on the deck, bum in the air. Soft softly at first…
cliff
15 Apr 2004
various
I recommended starting with 240/320 grit to remove any surface irrugularities quickly then finer and finer poliching with finer grits up to 1200 grit - no need to go any finer - final polishing with a suitable polishing compound. Having done a number of "perspex" windows which were either solvent damaged or just scored the 240/320 grit made the initial resurfacing so much easier and quicker.
