Neil
Many small sailing boats, Drascombes, Bayraiders to name but two, are equipped with a small mizzen mast and sail. What is it about this size of boat that requires a mizzen to balance the main and jib?
It keeps the main mast lower than would be otherwise needed,
I think people turned away from ketches, yawls and schooners because they looked ugly.
JOHN ALDEN SCHOONER
Because they look nice?No-one appears to address the OPs question
The answers are valid for 50' vessels but hardly valid for a yacht 25' long
Why a mizzen when the sails are so small anyway? (on a small vessel)
Jonathan
By smaller I take you to mean dayboat size, where the boat is often designed to be trailed. The costs are not much more than a sloop as the rig can be light and simple. I have always thought the Drascombe rig looked very snug in strong winds under mizzen and jib.It just seems to me that smaller modern production boats often have a mizzen whereas most modern larger boats do not. Why do such advantages of a mizzen not translate to bigger boats?
Agree - the balancing of the boat is a big part of it. My mizzen is quite large and will provide drive but is often used to balance the main and jib. I know its right when I can cleat the wheel centrally and let the boat steer herself.The tiny mizzen on the Drascombe range doesnt provide much drive and is really there as a steadying sail to give balance---and for looks. It harks back to the rig on the naval whaler. Are there any of them left?
Agree with you about the comfort factor and anchoring. I can drop and retrieve my anchor under sail using the mizzen to stop the bow blowing off, which makes handling 10t of boat simple.I owned a Devon Yawl for many years. One advantage of the mizzen not so far mentioned was that if wind was against the tide on the mooring I could often set the mizzen first, small enough not to be a problem, the boat would usually then swing into the wind or near enough such that the main could then be hoisted before dropping the mooring. A real advantage if single handed. On a breezy day with lots of family on board she sailed well with jib and mizzen and no risk of anyone getting clouted by the boom.
As far as performance was concerned the mizzen was probably a hindrance. Certainly the Class Rules of the Salcombe Yawl, from which the Devon Yawl was derived, require that the mizzen shall be set at all times as they sailed faster without.
