Wandering Star
I don't think the price differential is to do with cost of materials, it's to do with the hull moulding and fit out procedures, at least that's what I've always understood. Any sort of encapsulated keel, tumblehome. non-straight sheerline etc etc, means the boat has to be built using a 2 part mould which is bolted together, you can't release an "odd shape" moulding from the mould using a one piece mould. The "seam" of the 2 piece mould has to be filled and faired (which is a skilled job) after each and every hull release and the mould has to be polished as an integral unit after each release. Then the laying up can start.
Whereas an AWB production mould is a one part mould, the design is always going to be saucer shaped to one degree or another. The laid up structure is ejected or "popped out" using high pressure air between the hull sides and the mould. Because there's no "seam", the mould can be used again immediately.
With a one piece mould, slots for bulkheads can be included in the mould so that when fit out commences, it's just a matter of dropping bulkheads and furniture into the appropriate slots and they're correctly positioned every time. That's obviously not possible with a 2 part moulding. I think for the same reason, the lid can't be put on a 2 part moulding quite as easily as the 1 part moulding because of very small variations of alignment.
And other stuff! So that's why even if there was a standard interior, it won't decrease the building cost to anywhere like the same cost of an AWB.
I don't denigrate AWB's, but if you do happen to want an encapsulated keel, a shapely sheerline or a wineglass shaped hull, it's going to have to cost a lot more even if you produce a standard product. It's all down to production costs and the materials are only one element of cost.
Cheers, Brian.
