oldgit
Everything and anything and above all do not get them wet !
Spot the shafts- this my stomping ground BTW
http://www.youtube.com/watch?v=4y69Gd6rIeo
lot of luck people on here claiming trouble free drives. The vast majority of them talking about relatively new boats in the first 10 - 15 years service.
The OP was wondering about older boats. Only one guy so far with an old boat and a good experience.
It all goes back to KISS, and drives multiply the complexity and opportunity for grief tenfold as they get older.
Where exactly did I say that? What I said was that an old boat with simple and robust engineering with most of its moving parts protected inside the boat, stands a better chance of reliability than a complex, delicate equivalent immersed in seawater.There must be a lot of scrap boats about then if everything beyond 15 years old with drives is a waste of time and money...........
A bit harsh really Oldgit!!
There are 100's of 1000's of stern drives out there in use so they cant all be unreliable
Pop down to your local boatyard and wander around looking at everything ashore for repairs....
Count the number of boats with mysterious large gaping holes in the stern or even more frequently a corroding aluminium transom assembly with a few miserable hoses dripping hydraulic fluid.
Easy to tell how long the boat the boat has been there by the amount of vegetation dying around it.
Nasty horrid things.
You would expect to see flybridges out at this time of year.Actually the last walk around the yard at our marina (last weekend) highlighted a large number of big flybridge shaft drive boats ashore.
From personal experience owning a Mercruiser and chatting with US dealers, I've come to the conclusion that stern drives are designed to serve the first owner well but after 5or 6 years you have had the best out of them. The manufacturer only care about the first owner.
The second problem is, that with all the good intentions in the world, in most of the UK, away from the south coast, getting them serviced is difficult and repaired properly, nearly impossible.
If Honda / Yamaha / Suzuki started to build them AND the leg units were available on a service exchange basis (they are very easy to remove and refit) then I might consider them again............otherwise, no thanks.
Mikej
They aren't rebuilt - they're new. But nevertheless, you musn't miss another opportunity to tell us how ker-rap they are...
