Javelin
I think we launched 12 boats this week and for once only two out so at last we appear to be winning.
The Ovni went in and is looking good however it wasn't plain sailing.
Firstly the c/board wouldn't go down as I discovered backing out of the slip in 20+ knots of wind and an 2.5knt flood tide.
On the positive side I quickly found the new bow thruster worked well !!
I found with the wheel hard over with a blip of forward thrust coupled with the corresponding bow thruster I could make her go sideways into the wind which was really cool.
Once safely moored up we discovered the problem was that the two layers of antifoul on the keel were to blame.
After a few ups and down of the board it cleared itself.
We also had a little issue with the rudder which is hydraulically pumped up and down.
However we found that if you pump down too much the ram goes out of center and you cant pump back up again.
Silly design really and what was really strange is the hydraulic pump manufacturer recommends using antifreeze for the fluid.
Should be fine for the season but we'll have a proper look at it in the winter.
Rest of the boat systems are great, the new windlass, Rutland genny, windows, furlers etc and the new paint look superb.
I've included a shot of the bow thruster taken from the inside below.
Pleased with they way that all turned out as the owner had to take a bit of leap of faith with me.
One of the boats that we did lift was a Nauticat 33 which we'd worked on a couple of years previously and had shipped off by road to Cardiff.
The owner had issues with his gearbox and a number of yards had tried and unsuccessfully found a solution so they sailed her back here over the last year.
Engine is now out and our engineer is having a go, will report back later.
We got in touch with sillette who are the UK dealers for Gori props and explained that with less than 80 hours clocked since the vulcanized bush was replaced was not very good.
A deal was struck and we now have a new prop for the cost of another repair.
Thanks Sillette.
Talking of props we changed a cutlass on a Moody 36 and the prop and shaft had been treated with Prop speed almost a year ago.
The results were impressive but given the cost of application it should be I guess.
Probably well worth it for a diesel hungry power boat but on a yacht I think its hard to justify over our current favorite, International Trilux.
Fitting a 100lt holding tank which has the std 1 1/2" pipe fitings.
However the new loo complete with macerater has a 1" outlet.
A pain but we checked and using a reversed reducer we can go from 1 to 1 1/2 with no drop in performance even over the rather convoluted route the pipe will have to take.
Thanks Sillette.
