Agree not a suitable boat - although nothing wrong with the glued in windows. Many thousands of those in use without problems. However those skinny T shaped keels are just not appropriate, although if properly built to the current standard it should not fail under normal sailing loads. It is a 2010 Grand Soleil 46I am with Sea Change and wouldn't want to sail let along cross Atlantic with a keel like that. Wrong choice of boat in my humble opinion and not just for the keel design. Look at those glued in hull windows.
Who where those Youtubers who took on a similarly damaged 40 odd footer? Huge amount of work.
In their situation I think the boat is scrap, insurance may pay out and sell it to them if they want to take it on. Without dropping the thing, it should not be possible to damage a properly designed and constructed cruising boat in that manner.
If they had read this forum, they would have bought a banged up Westerly & still be varnishing the wood bits 3 years laterInteresting to know their des is ion to buy that boat with that type of keel I am sure if they had visited the forum they would have made a more informed opinion
Don’t besonegative!If they had read this forum, they would have bought a banged up Westerly & still be varnishing the wood bits 3 years later
Have not looked at the regulations for Class A, but having looked at the companionway washboard fittings on two large class A boats. As a result of these details I have doubts as to how much the regs can be trusted to produce a safe ocean going boat. Both boats had transparent washboards around 5mm thick, which are probably up to the job. My concern was the fastenings, a very light and shallow alloy channel that looked as if it was held in by four self tapping screws on each side. Even if machine screws with nuts on the other side the whole arrangement was flimsy. The sides of the campanionway were parallel smooth fibreglass. It would have been possible at the design stage to make a step in the side mouldings to support the washboards in the event of them being pushed forward by water pressure or an intruder. Left me wondering what was the rest of the boat like.But a competent naval architect would have designed that boat, ensuring it met with appropriate regulations for presumably a Class A Ocean RCD or equivalent.
And still be arguing about the best anchor set up!If they had read this forum, they would have bought a banged up Westerly & still be varnishing the wood bits 3 years later
I agree the CE class A certification is largely worthless. Its main effect is increasing the cost of vessels for little benefit. Some of the rules are counterproductive. Unfortunately, some other marine standards such as those that certify anchors are drafted in the same poor way. I think it is time for a revamp.Have not looked at the regulations for Class A, but having looked at the companionway washboard fittings on two large class A boats. As a result of these details I have doubts as to how much the regs can be trusted to produce a safe ocean going boat.
Hi Doug the youtube site was 'expedition evans' https://www.youtube.com/results?search_query=expedition+evans+1Who where those Youtubers who took on a similarly damaged 40 odd footer? Huge amount of work.
