Why do boats use nautical miles and why are they different than normal miles? Couldn't you just convert it to normal miles or km?
Buck Turgidson
10 Apr 2012
Zürich
I own a number of rifle scopes, some calibrated in MOA others in Mil Rad. They all work. If im ranging in Yards I use MOA if im ranging in Meters I use Mils. If you want to use degrees then Nautical Miles is the solution for navigation. I think the French tried and failed to convince the world to change.
DangerousPirate
24 Feb 2020
N. Ireland
Don't they always
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
The French did try to decimalize everything, and if their original plan to link the metre to the Earth's circumference hadn't fallen flat because the length of a degree of latitude changes by about 1% from the equator to the Pole because the Earth isn't a sphere, it would have worked. Grads (a hundredth of a right angle) are still used for some survey purposes in France, I believe. But if the French scheme had worked 1 grad would be equivalent to 100km in latitude, and it would all have worked fine for navigation; a centiGrad would be a kilometre. But as the metre was intended to be a fixed unit, unlike the nautical mile which, for navigational purposes is very slightly flexible, so they abandoned the original definition in favour of the distance between two marks on a bar of platinum at specified temperature and pressure. Things have changed even more since then, and it's now defined in terms of the wavelength of light produced by a particular subatomic transition, which means it is tied to the speed of light!
Sandro
20 May 2004
Northern Italy
rotrax said:
Seen lots of stuff on here, some of it a bit uneccessary if the way it was explained to me years ago is true. I have no reason to believe it was not, so what I was told is this :-
The circumference of the world at the equator was measured/calculated and subsequently divided into 360 equal lengths, each length then became one degree.
Each degree was subdivided into minutes and seconds.
The resulting size of one second of a degree at the equator became a Nautical Mile.
Seems pretty reasonable to me, and is the reason a land mile differs from a NM.
As only Refueler noticed one nautical mile is one minute of a degree, not one second.
requiem
20 Mar 2019
I think many times new units arise from being "close enough". Long years ago when the Babylonians used a sexagesimal numbering system, it could be debated which came first: the system or the recognition that there were close to 360 days in a year. (Don't ask me, it's been far too long!)
Its worth noting that they didn't use a pure base-60 system; it was still base-10 at its core, but in any case it persisted for many things and in particularly those where circles and angles were involved. My money is on people observing, after using degrees and minutes to measure the planet, that a degree was very close to 60 miles in length and thus opted to use that as a convenient "close enough" reference.
It's important to remember that back then there wasn't really a "standard" mile; each country or region had its own idea of the size of a mile (or foot, inch, stadion, etc). It is only recently (in relative terms) that measurements have been standardized, and even so it has been barely two years since the US side formally retired one of the two different "foot" definitions in use.
This part I would quibble with; if you treat the mile as varying rather than fixed you introduce more problems for close work. On an angled course, would the east-west component similarly vary in length with the difference in latitude? E.g. is a 100 mile course due west at 80 °N of a different length compared to a 100 mile course due north that starts at 80 °N? Does one need to re-calibrate their log as they progress further towards the poles?
I know the differences are minor, but here I would argue that the nautical mile itself is not changing, but rather the use of the latitude scale is merely a "close enough" convenient shorthand for chartwork that has the additional benefit of correcting for chart distortion.
Refueler
13 Sep 2008
Far away from hooray henrys
As I recall - someone may find the actual definition ... but the UK Statute Mile was derived from Elizabeth 1 and Hampton Court gardens I believe ... it was not as the metre based on a specific scientific item.
If you were to stand on the earths surface - you can take any point you wish ... walk 100nm in any chosen direction ... turn 90 degrees and walk 100nm ... turn again 90 and walk 100nm ... turn again to get back to starting point - you would NOT walk 100nm to reach that exact spot again ...
I think you are mixing up two factors. Yes the Latitude scale is distorted because of the Mercator projection that takes the oblate spheroid earth and flattens it out to a square. If you imagine the N and S poles opened out to fit that square projection - then the Poles become infinity distance on the chart ...
The problem comes when trying to plot on any projection that allows polar regions to be more accurately depicted ... and is why such as my Father used the 'Grid Nav System' for trans Polar Flight checking. In simplest form - the polar region was disregarded in terms of Lat / Long and treated as a grid like graph paper ..
The second factor is the actual variance of the physical distance one minute of angle on earths surface covers ...
The two factors are NOT the same and cannot be combined in same factor.
sfellows
15 Jan 2007
A man walks 1km south, then 1km west, then 3km east and spots a bear. He then walks 1km north and arrives back where he started from. What colour was the bear. :) :cool:
RunAgroundHard
20 Aug 2022
Sure, but it's a little bothersome to change between litres per mile/km and litres per nautical mile among being able to feel distances out right.
There is no viable alternative yet, but are there any reasons for why it couldn't be replaced?
And I am not even advocating for it, I don't mind using this system. It's just a thought experiment.
Consumption is usually based on time and not distance on a boat. Therefore it’s not an issue calculating range in hours, days and comparing to ETA or planning future refill. You just don’t need to convert.
Buck Turgidson
10 Apr 2012
Zürich
In these "enlightened" times, I'm not sure if that question is appropriate! I'm feeling a little triggered by your non-hate non-crime.
