Alanarkison
Fairline phantom 43 with twin Tamd74P engines. Bought with a known fault that both engines wont rev passed 2000 RPM with morse lever all the way ahead. Engines just get to about 70% and then there's no more. Previous engineer changed injectors, fuel pump, turbo chargers and boost sensors. They were using Jaltest to connect to the ECU but thought that the fuel pump rod was 100% WOT but we've had the local Volvo engineer down today and plugged in with Vodia to both engines and it showed max fuel rod position of 67% with morse lever full ahead. No fault codes shown so my thinking is that the EDC would call a fault if the fuel rod isn't where it should be or if the actuator wasnt moving the rod correctly ( codes 2.2 and 2.3). So the EDC thinks that the fuel rod should be where it is. Ive attached the picture of the scan. boost pressure seems normal at 185 KPA (27psi) for 1900 rpm. Interestingly relative load is at 100% with only 1912 rpm and 67% fuel rod position. EDC only restricts fuel on air inlet temperature (27 deg C) or boost pressure ( 27 psi) but both seem ok. Im thinking this is software related and that the EDC may need the software reloaded. Does anyone have any other ideas.
