TwoStroke
Boat setup - twin batteries - voltage check show 12V reading on each. Batteries then go through main switch 1,2 or both.
Engine off - voltage check on dash shows 10V - voltage check from fishfinder lead shows 8.5-9.0V. Engine on - voltage check on dash show 13V - from fishfinder lead 8.5-9.0V. Need between 10-11V for fishfinder to work.
Am going down to boat this weekend - am not sure how I can have such a huge reduction in voltage - it was only a few weeks ago it was working all ok! Voltage check on dash used to show 13V when engine off too! /forums/images/icons/frown.gif Have connected fishfinder direct to either battery - works all ok. Any suggestions as to what to look for here and what could be causing the drop?
<hr width=100% size=1>How much to fill'er up!
<P ID="edit"><FONT SIZE=-1>Edited by TwoStroke on 25/07/2003 09:45 (server time).</FONT></P>
