bitbaltic
Ou can set them for anything you want, it’s just a movement with a rotary wheel on the mechanism to set it.Can you set them for a home port or are they set to high water Dover?
We’ve got one (a weems and Plath)- bought it as part of a set of three with barometer and thermometer mostly to cover up a bunch of screw holes from previous clocks fitted to the bulkhead by previous owners. I like it well enough, in the Bristol Channel tides are symmetrical and it’s no bother to adjust it to wherever you are. But the mechanism is failing and needs replacing (the ordinary clock runs slow with any new battery) and with navionics tides on the iPhone I do t use it (or the almanac) on any regular basis.
I still entertain fantasies of long passages noting barometer pressure and temperature to forewarn myself of winds in the classical manner. That’s why the instruments are still there (and, of course, the increasing problem of a multitude of ugly holes in the bulkhead should they be removed).
