Bouba
I can describe the quantity....I know the French for coffee cupIt was the quantity to show never mind to late now.
No bouba your comments should be left for all time for everyone to see.
You still have not addressed the problem and I bet not kept the stuff to show the generator person.
In about the first page or so of the thread Bouba spoke of both rust and corrosion, that he used WD40 and a screwdriver to dig it out, that he'd dug out handful, and I think at that point it was still preventing the seacock from closing.It was the quantity to show never mind to late now.
I got the launch postponed to Wednesday...mostly because of the wind. Pulling the generator apart before the technician arrives is a bit premature....my first thought when I saw the rust was the seacock...turned out not to be...which is a shame because it’s the cheapest optionIn about the first page or so of the thread Bouba spoke of both rust and corrosion, that he used WD40 and a screwdriver to dig it out, that he'd dug out handful, and I think at that point it was still preventing the seacock from closing.
But Bouba seems determined to do anything but address the issue that was concerning him.
We just need to know from him whether he is still launching on Saturday.![]()
Yes...but I wanted to replace my thru hulls with Trudesign for a long time...this was my chanceWhat a surprise!
(We told you it almost certainly wasn't!)
What is the real issue???Lovely. But you let it distract you from dealing with the real issue that needed addressing.
Never mind, though. I've got some boattorturemaintenance coming up imminently, so you can get your own back!![]()
It can only come from the generator...between the generator and the exhaust separator (which I think is plastic)...so...for the twentieth time...THE ONAN ENGINEER IS COMING AS SOON AS THE BOAT IS IN THE WATER....I will tell you exactly what he says (if he speaks Franglais) as soon as he says itThat your through-hull and seacock was full of what you said you thought was rust and corrosion (to the extent you could close the seacock). You still don't know whether that is what it was or where it has come from, and if it was rust there's something somewhere in your boat that is a lot thinner than it should be (or worse).
I should just follow your example...give up and find a comfortable monasteryCan you shrug your shoulders and shake your head in a forum post.
A nunnery is to be preferred.I should just follow your example...give up and find a comfortable monastery![]()
I’ll take your councilA nunnery is to be preferred.![]()
That's very wise of you as yesterday evening has provenI’ll take your council
I can’t deny that piety is it’s own rewardThat's very wise of you as yesterday evening has proven![]()
What value has this guy got , to let it get into this state ?It can only come from the generator...between the generator and the exhaust separator (which I think is plastic)...so...for the twentieth time...THE ONAN ENGINEER IS COMING AS SOON AS THE BOAT IS IN THE WATER....I will tell you exactly what he says (if he speaks Franglais) as soon as he says it
It’s a company...let’s get a diagnosis first before we point fingersWhat value has this guy got , to let it get into this state ?
What’s the previous yrs invoices say ?
I’m hoping that rusty pipes are an easy cheap fix...and that is the only problemThe diagnosis is simple you got a large amount of rust from somewhere betweenthe intake and the exit of the water pipe.
If is not the intake valve and the otherparts are plasticwhere can the rust have come from?
