Brent Swain
N/A
Cruise BC, where you have plenty of room. Your solution is to not know if it is set, until the middle of the night ."Big problem, especially on aluminium boats, on which it is hard to find an antifouling which wont eat the aluminium.
Was in Samoa with fouling problems. Could be hard on the wind to Tonga.So I pulled a big poly tarp under the boat, and let it float up against the hull.Then I poured a gallon of bleach in ,and let it soak overnight. Next day, all the fouling fell off, leaving a super clean hull."
Tosh, absolute tosh. There are numerous AFs designed for aluminium boats. I sailed on several big ali racers in the 1970s and not one of them had its hull eaten away.
______________________________________________________________________________
RCMP catamarans here are looking like Swiss cheese.
____________________________________________________________________________-
BTW, your environmental credentials .... bleach poured willy-nilly into a fragile environment in Polynesia ? ? ?
Locals are dong it all the time, as are most urban land dwellers . Chlorine reacts quickly becoming quickly neutralized , What is salt? Reacted NaCl, a chlorine compound. What is your solution to that situation?
NONE!
_______________________________________________________________________________
And your anchoring technique makes you a total liability and risk to other boats if your anchor fails to grab.
When did I ever advise pointing your bow at another boat, when setting the anchor?
