GregOddity
I suggest you add a couple of propeller shear pins to your list.
yes.. i realised that i needed shear pins and 2 spark plugs as a back up. I really could have used the later...But thank you for reminding me.
Rowing an inflatable. I have told this story before but perhaps worth repeating. An elderly couple very experienced sailors anchored their boat some distance off the shore at Rottnest. Inflated the dinghy and rowed ashore for a get together. Later that night they rowed back to their boat in the inflatable. The wind was behind them when rowing back. It is assumed they missed grabbing the boat and were unable to row back against the the wind. Inflatable found next day empty about 10NM down wind one body found one not found. The lesson is that you need to sort out a decent anchor and rowing arrangement for an inflatable. olewill
You have a point. My anchor needs a proper upgrade. Maybe not a 50kg Mantus but I do need something that will hold on mud. This one might as well have some bait put in it and be used for fishing in that type of bottom. We did not even notice slowing down. Which we did not.. So Yeah a New one needs happening.
For what it's worth, I got one of the smaller sizes of Fortress for an inflatable high-speed catamaran (ZapCat style) that a friend persuaded me to unwisely buy into. Of course it doesn't fold like a grapnel, but you can break it down into a few pieces that pack together neatly into a long narrow package and just need a couple of nuts tightened (leave them in place, just loosened slightly so they don't grip the stock and you can slide it out) to reassemble it. I made a bag for that one too, and put the necessary spanner on a lanyard inside it so it wouldn't get lost.
That anchor held us very nicely against a strong tide on a couple of occasions.
The only thing people ever say against Fortresses relates to the tide turning while you're asleep on board, so is irrelevant for dinghy use.
Please take a take a minute to reflect on this. I found an inflatable 23 Nautical miles of the coast, west of Sagres Point in Portugal in 1986. Inside there were 2 people in very bad shape. They had been adrift since 6 am when the outboard run out of fuel, they went out for night fishing, they took a sandwich and a bottle of beer each. I found them at 21 30 PM something if I remember right and only by pure coincidence as we had decided to tack for the hell of it. It was July, the temperature was above 40 Celsius the whole day and was still 36 when we brought them on board. They had NOTHING. no radio no water no tools no life vest not even anything more than a t-shirt to wear. They both survived, but one a German from Berlin spent 3 weeks in hospital after being flown to Lisbon the other also a German spent the rest of his 2 weeks holiday in Hospital in the Algarve where the food is great and the wine divine. He did not have any of that of course. They were both " well done" and crispy from the sun and dehydration.
What did I learn from that? I carry a white and red flare, 1 flashlight with a spare battery, 1,5 litre of emergency fuel 2x1.5L of water, small anchor, 30m 12mm line 2x kill chord a spare oar, VHF portable at all times. It all fits in the under the seat bag and hope to never need it. I did use the anchor and line and the flashlight and water in the last “incident” Everyone will also have a personal lifejacket with life line. Or they stay ashore. No discussions or even academic debates.
But hey thats me.
I have. Directly due to this thread.
My tender is possibly a bit smaller than yours. A roll up inflatable with slats, a plastic seat and those very annoying oars.
Rowing it can be quite awkward.
I chose a small rollup because I roll it up and take it home in the back of the car. so being able to carry it up and down to the car by myself dictated the small size. Only have to row out a couple of hundred yards in to the harbour. Not much current but its quite exposed to the wind.
But a small anchor is not a hard addition to make. If you ever need it. Sucks not to have one.
My main concern has been taking a tumble boarding the boat.
I have just checked my local requirements. human powered less than 6m. Anchor not a requirement but 15m line is. so I may be putting together a little tender pack.
Put a motor on it and the requirement list grows. But anchor or paddles.
I have a pack for my runabout which includes all required gear. including an anchor.
Which is probably more like the fishermen.
I downsized a couple of years ago. Its a bit small for offshore fishing. But it does have a fitted radio. In addition to my handheld. along with a simple tool kit and spares. My previous runabout I used to fish offshore. Radio just a hand held. I like the fitted radio now. Never used it but nice to have.
Being able to replace a split pin. Since I use it for fishing. Being able to remove a propeller to get line off. A spare pin for the prop is a good add to the kit.
I think if I used my tender as a small runabout in addition to just to and from the boat. I probably would have more kit.
It’s the things we do often that place us in the most danger as we fail to recognise the danger. The Sea is ALWAYS the master and decides what happens and how. We are either prepared or suffer the consequences of our hubris.
I really am beating myself over the anchor. I just bought “an anchor” in order to have one on board without any consideration whatsoever how I may need to use it and in what type of conditions.
When the time came to use it. Off course it did not work. Wind and inflatables is not a very good combination. The Inflatable always loses. You row out fine 1000 times, then one day you lose an oar or hurt yourself and get swept out.
I had nothing to tie too and could not make any headway rowing like a crazy man. And I can row. That anchor is not fit for purpose for those type of conditions or bottom. So stupid me.
I do not see the point in an anchor. If it was so rough that I could not row I should not be out there in the first place. Light anchors will not grip & the depth would soon be too great unless the line was long. Then having to transfer that back& forth to the boat every time would probably be more dangerous than not having one at all.
The point about loosing an oar is valid. I have been rowing Avons since the age of 12 & right from the start I tied a cord across the handles & have done so to this day. An Avon is one of the few dinghies that can be rowed well once the technique has been learned.The first mistake is trying to do it with 2 people side by side. They can never get the right balance & get a clear sweep of the oars. Just one person so the action can be properly controlled.
I do not see the point in an anchor. If it was so rough that I could not row I should not be out there in the first place. Light anchors will not grip & the depth would soon be too great unless the line was long. Then having to transfer that back& forth to the boat every time would probably be more dangerous than not having one at all. I do have a rond anchor for the painter if I want anchor the boat on a beach or a bank. This is far better in an inflatable & can quickly be clipped to the painter when needed & is fairly light & safe
However, I do carry the pump when in a strange location. I always wear a life jacket & mine has a pack of 10 mini flares & a PLB attached. I always have an LED torch in my anorak pocket. So I feel that somehow I would either drift ashore somewhere, or at least be able to summon help.
I disagree on the anchor. I carry 30m of 12mm line, that should very well give me purchase on most bottoms and coastlines and if adrift on a delta somewhere it would still be able to reach bottom.
The point of being prepared is to be able to use it in need. Off course I do not intend to challenge weather or Sea as they tend to always win. But I did get caught on weather NOT of my choosing and seas not of my choosing on a powerboat with a crippled engine that was barely running. Did I want to be there? NO, would I ever go out in that weather? Hell no. But there I was in the thick of it and I fought like hell not to end up on the rocks of the shore for 18 Hours praying that the engine did not die completely. The point being that once on the Kingdom of Neptune, you are his subject and he does what he does with total disregard for you.
So if I’m on a dinghy that can be taken by the wind, I do think that having the means to at least slow my drift so that IF I get caught in a bad situation turning worse I can at least slow down the drift or be able to stop in place and ride it with oars working at the same time if needed until I’m able to raise help.
The thing is: without an anchor to slow you down, Whoooooosh you go where the wind and tide decides. I rather not.
As I understood it the OP's original post was about his TENDER which suggests that he wanted to get from shore to a moored boat. I was not talking about being out in a powerboat especially offshore. That is a totally different scenario
A very odd point of view and totally against the consensus.
Well if it is the consensus, just walk round & have a look & see how many tenders ( as opposed to dinghies used for fishing etc) you can find with an anchor on board.
It is OK sitting in the armchair in the lounge watching Eastenders, whilst typing on the forum, but actually DOING it is sometimes something totally different I suspect.
I say this with all due respect, & i am not trying to score a point at your expense in particular but:-
If it is the consensus, just walk round & have a look & see how many tenders ( as opposed to dinghies used for fishing etc) you can find with an anchor on board.
That sort of makes a mockery of the " consensus" does it not?
