Suez blocked.
Tanqueray
26 May 2011
On the other hand there are 40 million Iraqis and a good land border, so that could be where they are going. Certainly I’ve carried American rice to Aquaba for Iraq, before all the Late Unpleasantness.
A typical livestock carrier will take 3 or 4 thousand head of cattle. There are bigger ones but I think they are in the Oz/Saudi trade.
I’m struggling with 85,000 head on seven ships.
Could be Egyptian sand dance cattle - they have a head at each end.
Thistle
2 Oct 2004
Here
Stork_III
6 Aug 2002
Here and There
Ryanair maritime?
Bajansailor
27 Dec 2004
Marine Surveyor in Barbados
Worse. The livestock trade by sea is truly grim, and should be stopped.
We’ve been campaigning to get it stopped for three years now.
Are livestock carriers synonymous with disaster? - Splash247
A quote from the article -
"To avoid such failures, getting away with the monohulled construction is a convincing option. Innately, such hulls are not adequately stable and fit for the purpose as livestock carriers. Replacing the same with a multihull like catamaran or trimaran will significantly enhance the stability which is the most significant weak element of most livestock carriers today. "
A multihull type of hull form sounds very logical to me - although the article also notes that there are very few purpose built livestock carriers.
Most have been converted from old container vessels.
And there are not many old multihull cargo vessels knocking around that could be converted.
And the owners naturally do not want to build a new ship if they can re-fit an old container ship at less cost.
And they do not appear to be too perturbed about drowning a few thousand sheep or cows :(
And of course, the reason why they have livestock carriers in the first place is because the animals have to be slaughtered the halal way - which in itself is very barbaric.
It would be nice if a law could be established banning this trade - if the folk in Saudi et al want mutton and beef from abroad, I am sure that it would be much cheaper in the long run to import it already processed in reefer containers, rather than 'on the hoof' - and much kinder for the animals as well.
But no, they have to do it the 'traditional' way. :(
Rappey
13 Dec 2019
This thread has been fascinating. With a few on here with specialist knowledge and Kukri being spot on with his thoughts . Who needs the media!
I noticed today on the radio all the "experts" coming out of the woodwork to give their 10p worth yet were silent until the ship was freed. ?
@Kukri , if you don't mind may I ask what your occupation is, or what you do ?
Bilgediver
6 Jun 2001
Scotland
That's a terrific amount of beef to eat every day! I'd guess that the average Jordanian probably only eats that in a week, so them cows would probably keep Jordan going for a month or two.
Maybe another chip is carrying spuds.... They had a cargo share out courtesy of The Underwriters last time the canal was blocked. My brothers crew needed help to eat the apples on the Port Line ship and some were traded for alternatives/
DJE
21 Jun 2004
Fareham
www.casl.uk.com
Could do with some for my Mill ponds if you've got any left over :)
I cannot see it being fully lined (and I'm guessing that the lakes at least are natural water retainers) - but the ymight have some porous areas where they need to at least slow down the leakage??? I'm just musing.
No need for waterproof lining. It's a sea level canal and the water table is never going to be lower than sea level so there is nowhere for it to leak to.
Tanqueray
26 May 2011
This is something that I have never given a moment's thought to in my life (possibly because it was mostly spent on the sea not the land).
Can you talk me through this please - the canal bank in the photos where the digger is excavating around the bow of the ship seems to be about 6-8' higher than the canal - are you saying that the water table there will be at some height between the canal level and the surface level (even though its desert)?
newtothis
28 May 2012
Not entirely. A number of freezing works in NZ started doing Halal butchery so they could export to the Middle East. Kept a few of them going during the bad years in the 80s.
DJE
21 Jun 2004
Fareham
www.casl.uk.com
Groundwater flows downhill from areas with a higher water table to areas with a lower water table. If there is no flow then the water table is level.
Over hundreds of years seepage from the sea saturates all coastal rocks and soils up to sea level. Rainfall over the land seeps into the ground and raises the water table above sea level, this causes the water to flow towards the sea. If there is no rain over the land then the water table will be horizontal at sea level and there will be no flow. The Red Sea and the Mediterranean don't have waterproof linings but they don't drain away because the surrounding rocks and soils are already saturated up to sea level.
If you took the digger a few hundred yards from the canal bank, which is say six or eight feet above water level, and dug a hole ten feet deep then it would fill with water up to the same level as the canal water. This may take some time depending on the permeability of the soil but eventually it would reach this equilibrium level.
