ThomasMartin
Looking for some advice.
A few months back we replaced the old knackered yanmar 2QM20 in our sailboat and installed a newer and more powerful Perkins perama M30.
We were sold the Perkins to us by Marine Enterprises Ltd for around £2800 for this we expected a fully reconditioned engine.
However when the engine arrived it was in a somewhat shoddy state; air intake was filthy, oil was black as night, control panel was sort of compatible, missing engine mounts (mounts clearly visble in the ad).
We emailed them to notify that we were dipleased with the lack of servicing done, they reply telling me how to rectify this and that they would sent out engine mounts as way of an apology.
These engine mounts were never sent out to us and we to order them ourselves at the cost of £120 as the launch date was quickly approaching. I contacted them again asking where the mounts were and never got a reply.
When testing the engine I found the tachometer was none functional and spent a considerable time consulting the workshop manual and a marine engineer about this issue. It was all wired up correctly with ground and T+ on the alternator, the alternator was working as it was outputting a decent voltage, clearly the tachy was faulty. didnt have the money to replace the tachy having spent so much on everything else.
So we were lifted in and commenced sea trails, a short sail to an anchorage a few hours away. The sailing was good but had issues with the Perkins starting, turned out to be air in fuel lines, easily remedied (cracked the injectors and reprimed).
leaving the anchorage had same issue, clearly something was amiss, pulled the injectors and found they were dirty and clogged, cleaned them, reprimed the fuel system and she fired straight up.
A few weeks later we took the boat to an achorage near our home port, approximately 5NM away. There wasnt much wind that day so had to fired up Perkins. Started and ran fine on the way there, nice sunny day fishing at the anchorage and returned home, ran fine on the way back to. A round trip of 10NM, 3 hours of motoring, just cruising along.
Went to start the engine the next day, kluck! nothing, no turn over. on closer inspection found all 3 cyclinders were filled with coolant. With abit of research deducted that the engine must have overheated and blew the head gasket, but why? hadn't run perkins that hard at all. Turned out the heat exchanger was very corroded on the interior and the coolant pump as well.
I contacted Marine Enterprises asking them to send out replacement parts, we'd had only brought the engine about 4 months prior and used it a total of 2-3 times and obviously this fualt was there when it was sold to us.
They're have not responsed at all to my repeated messages, for almost a months now. so here I am with dead in the water, having been ripped off.
What should I do?
What should I do?
