wheels
I have an Oceanis 411 and I intend to replace all the skin fittings over the winter, I would like to use Tru Design as they should last the life of the boat but because of space restrictions due to the hull and bulkheads I will not be able to use Tru design fully as they do not have an extensive range of bends, T's etc. I am thinking about using bronze through hull fittings, T's and bends and Tru Design ball valves and hose tails, where I can fit Tru Design totally I will do so but there are 45 or 90 degree bend fitted to the through hull then the ball valve in the heads, not the best practice but I don't have any option apart from doing the same, I am not going to hack the boat to pieces. Does anyone have any experiance of mixing Tru Design with Bronze
